Author Topic: Scholl users?  (Read 3300 times)
Offline K9
  • VW LifeStyle
Scholl users?
« on: October 12, 2015, 07:48:26 pm »
anyone tried Scholl S3 Gold, 17, 30, 40? what pads etc and results?
dansmith180
Re: Scholl users?
« Reply #1 on: October 12, 2015, 07:54:30 pm »
The Scholl compounds are good, for a golf I would use S3 and one of their orange waffle pads followed by S40 and one of their black waffle pads
Offline white91
Re: Scholl users?
« Reply #2 on: October 12, 2015, 08:49:08 pm »
I've used s3, s17 and s40, with lake country pads, would use scholl spider pads next time
Offline K9
  • VW LifeStyle
Re: Scholl users?
« Reply #3 on: October 12, 2015, 09:14:15 pm »
can S30 be used with a green or blue hexlogic pad for a mirror finish?
Offline white91
Re: Scholl users?
« Reply #4 on: October 12, 2015, 09:58:37 pm »
Totally depends on current condition of the paint and what machine you're using
Offline K9
  • VW LifeStyle
Re: Scholl users?
« Reply #5 on: October 13, 2015, 08:56:07 am »
Normal das6pro. Got a dull finish now :/
Writen with my fingers
Offline white91
Re: Scholl users?
« Reply #6 on: October 13, 2015, 06:38:30 pm »
In my experience s30 won't touch vag paint, I had to go to s3. I would suggest s17 or s20 black for a single stage. Then s40 to final finish
Offline K9
  • VW LifeStyle
Re: Scholl users?
« Reply #7 on: October 13, 2015, 08:46:04 pm »
What pad and speed for the final finish?
Offline Hevoshullu
Re: Scholl users?
« Reply #8 on: October 14, 2015, 10:41:29 am »
S30+ and a black hex with a rotary buffer will do a nice one-step polish for removing slight haze off of VAG paint. Key is to use a good amount of pressure during working and then finishing off carefully with lower rpm's and very little to no pressure at all on the pad. For a more serious correction a good combination would be S3G with an orange hex and then to finish off with S30 + black hex - again with a rotary machine. I've used both combinations with great success on black and red VAG paints.
Scholl products need to be worked a little different compared to the traditional Menzerna products for example. Scholl ones need more pressure and you can basically skip the warm up phase of the traditional "zenith" method - that way the process is a fair bit faster with Scholl products. With a correct amount of product on the pad there is also little to no dust during polishing. I really like all Scholl products and recommend them to everyone.
Offline xjay1337
  • -Receive: 377
Re: Scholl users?
« Reply #9 on: October 14, 2015, 11:13:36 am »
90% of all of the cars I have detailed have had Scholl used on them.
Primarily a hit or two with S3 Gold and then on VAG paint S40 with a medium pad gives a very very good finish, with no holograms.
For a single stage polish I would actually go for Sonax 4/6. Better than Scholl S20 black.
