Author Topic: p0299  (Read 4891 times)
Offline cutchie
p0299
« on: November 18, 2015, 06:21:51 pm »
So I've had the underboost fault for a wile now replaced the dv pcv and the waste gate actuator, this week I fitted a boost gauge and got the car smoke tested. I'm getting 4 psi and dropping to 3/3.5 and no boost leaks were found anyone any ideas where to go from here?
Offline cutchie
Re: p0299
« Reply #1 on: November 18, 2015, 06:30:48 pm »
Sorry waste gate solenoid**
Offline Ricky123
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,98436.0.html
Re: p0299
« Reply #2 on: November 20, 2015, 01:40:16 am »
Any mods?
Have you had a scan done with vagcom?
I'd double check all pipes, check intercooler for cracks too.
59 red mk6 GTi 5dr
57 mk5 1.9 TDi match
22 a3 s-line competition 45 tfsiE
09 Suzuki GSXR 1000 (road going track sl*g)
Offline Dan648v
  • -Given: 28
Re: p0299
« Reply #3 on: November 20, 2015, 09:33:43 am »
Had this code on my gfs a3 tdi and it was the actual actuator at fault. Replaced the unit and boom. Boosting again! Think the diaphragm had split inside?
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
Re: p0299
« Reply #4 on: November 20, 2015, 10:55:51 am »
So you've replaced the N75 rather than the actuator? Does sound like the actuator is at fault, not unheard of as mentioned above
Offline Dan648v
  • -Given: 28
Re: p0299
« Reply #5 on: November 20, 2015, 02:05:42 pm »
Take it to a garage and get them to vacuum test the actuator. That'll tell if it's working, that's what my Audi tech did  :happy2:
Offline cutchie
Re: p0299
« Reply #6 on: December 18, 2015, 12:27:29 am »
So thought I would update this I've now replaced the turbo and the fault is Still the same still peaking at 4psi every time anyone any other ideas?
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
Re: p0299
« Reply #7 on: December 18, 2015, 07:49:33 am »
4 psi is about actuator pressure when measured at the inlet
Data logging with VCDS is needed need to check all readings and whether the ECU is requesting boost (N75DC% - block 116 from memory - or thereabouts)
Offline cutchie
Re: p0299
« Reply #8 on: December 18, 2015, 05:12:22 pm »
003
114
115
Offline cutchie
Re: p0299
« Reply #9 on: December 18, 2015, 05:13:29 pm »
these are the graphs I logged but tbh I don't really know what im looking at or for! lol does anyone else see out anything out of place?
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
Re: p0299
« Reply #10 on: December 18, 2015, 05:54:29 pm »
Can you share a link to the CSV files? Are they full throttle runs?
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
Re: p0299
« Reply #12 on: December 19, 2015, 12:36:08 am »
Not really helpful as those logs were done separately.
Log these blocks:
114 115 118
001 002 003
031 023 231
091 118 003
So log 3 at a time on each run (press the turbo button), and do a single full throttle run in 4th gear from 2k rpm to as high as possible. Only log this - no other data
Someone else having the same issue on the FB Page TFSI Tuning:
https://www.facebook.com/groups/529405700525327/permalink/723181707814391/
