Author Topic: Dash Lights After Highline Install  (Read 5457 times)
Offline Lyons
  • -Given: 18
« on: January 23, 2016, 09:17:55 am »
Folks, I got a set of 973 R32 clocks fitted yesterday and the usual lights came on after. The steering wheel light went out after turning the wheel lock to lock, but the traction control and tyre pressure lights are still on. I've done a few circles in a carpark too and they haven't gone out.
I don't have vcds myself, but I can get it plugged in by a few others I know, but I'm just wondering if these can be cleared by it? Anytime they've come on in the past after having the wheel off, steering module out etc they've gone off after the above exercises. Just wondering if something different would've happened when fitting new clocks?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Dash Lights After Highline Install
« Reply #1 on: January 23, 2016, 09:50:19 am »
There r 2 more faults u need to clear using vcds. Where  r u based?
Its usually basic settings u need to perform on the abs section for groups 60,63 and 66.
Sent from my SM-G928F using Tapatalk
Offline Lyons
  • -Given: 18
« Reply #2 on: January 23, 2016, 11:31:37 am »
Belfast sadly!
Thanks, I'll get someone local to plug it in. I didn't realise vcds was needed to clear anything after.
Do you know why the washer low warning would be on now after too?! I thought it might just've been low and topped up but alas I wasn't that lucky!
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #3 on: January 23, 2016, 12:07:41 pm »
Belfast sadly!
Ive always disabled the low washer thingy on the clusters. Even with full bottle it still shows up and not sure why.
Offline Lyons
  • -Given: 18
« Reply #4 on: January 23, 2016, 06:48:04 pm »
Ah, more good news then! Cheers.
I didn't know you could disable it even. Do you know what controller its in?
Offline skard
  • -Receive: 245
« Reply #5 on: January 23, 2016, 07:11:56 pm »
It is in the coding of the cluster in 17-instruments, same place as brake pad & searbelt warning.
If you don't have the sensor in the reservoir, it will always say it is empty.
One time I fitted R32 clocks to a gti and the calibration process via ABS and the G85 sensor took a lot longer than usual, needs VCDS that is all.
Offline Lyons
  • -Given: 18
« Reply #6 on: January 23, 2016, 07:24:01 pm »
Super, thanks!
Offline Lyons
  • -Given: 18
« Reply #7 on: January 26, 2016, 06:21:55 am »
I might as well ask in here too, is it possible to get the speed displayed on the screen?
And can you turn off the compass so the clock is in the centre?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #8 on: January 26, 2016, 08:48:56 am »
If you have one of those fis boxes installed then u can display the speed in one of the parameters.  Not sure about the compass though
Offline neiller
  • -Given: 32
« Reply #9 on: January 26, 2016, 01:41:58 pm »
Who did you get to fit the clicks for you? I live in n.i and I'm interested in getting thisbdine myself !
Sent from my SM-N9005 using Tapatalk
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #10 on: January 26, 2016, 02:38:41 pm »
If your car is between 04-06 plate and u get clocks ending in 970,971 or972 you can buy the clone vag commander cable and do it yourself but you will need VCDS to clear error faults. vcds is around £260 - £300
Offline neiller
  • -Given: 32
« Reply #11 on: January 26, 2016, 02:42:14 pm »
Unfortunately my car is an 07
Offline Lyons
  • -Given: 18
« Reply #12 on: January 26, 2016, 09:03:19 pm »
Auto-Tune in Ballymena.
Offline neiller
  • -Given: 32
« Reply #13 on: January 26, 2016, 09:20:29 pm »
Did they just do the coding ? Or did the supply.the clocks and code
Offline Lyons
  • -Given: 18
« Reply #14 on: January 27, 2016, 05:24:39 am »
I got the clocks off eBay and brought them to them, they won't supply.
