Author Topic: Stock location big turbo and manifold  (Read 16122 times)
Offline bluo
« on: February 01, 2016, 09:17:55 am »
Been looking into a GTX2976R with stock location manifold allowing you to run current 3" DP - quoted power is 525hp
What are your thoughts on this?
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
Re: Stock location big turbo and manifold
« Reply #1 on: February 01, 2016, 10:18:01 am »
Traction is first thing that springs to mind..... You AWD?
Offline bluo
« Reply #2 on: February 01, 2016, 10:36:24 am »
Planning the build at the moment - awd is part of it.
Topic is turbo buddy, would like to keep it that way :-)
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #3 on: February 01, 2016, 10:48:49 am »
 :grin: indeed it is, my bad
Sounds exciting, you could always upgrade your downpipe to a 3.5 from Bcs if needed also  :driver:
Offline bluo
« Reply #4 on: February 01, 2016, 12:48:37 pm »
I'm looking at and talking to Nige at BCS re a full exhaust system - would really like to use their product hence one of the reasons looking at a stock location big turbo :-)
Offline KieranM
« Reply #5 on: February 03, 2016, 09:32:33 am »
You can fit a GTX30 in the stock location so you should manage a GTX29 but you obviously need a new manifold. Would you not need a new downpipe or modify your current one to use a v-band clamp?
Offline bluo
« Reply #6 on: February 03, 2016, 10:06:59 am »
Here's the turbo in question with stock...
http://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Store_Code=tp&Product_Code=ATP-VVW-290&Category_Code=FSI
Offline bluo
« Reply #7 on: February 22, 2016, 01:05:32 pm »
Bump- anyone got any experience with this turbo or the dbilas stock location turbos?
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=mjgh37bkjbpus3nv82du18fta8&/topic,19740.0.html
« Reply #8 on: February 22, 2016, 02:54:08 pm »
Why not go down the Nortech kit route?
Offline bluo
« Reply #9 on: February 22, 2016, 05:55:50 pm »
Trying to see if there is any advantage cost wise in using 'bolt' on bits instead of a custom tubular mani and downpipe.
Currently running a 90mm bcs downpipe so want to bolt on a big turbo.
Offline KieranM
« Reply #10 on: February 23, 2016, 10:34:13 am »
I think theses 29 turbos are fairly new and there isn't many people running them so you might struggle to find some info on them. I do remember someone speaking about them on TFSI Tuning fb page.
How much power are you hoping for?
« Reply #11 on: February 23, 2016, 10:42:19 am »
GTX2976R Is just a cast aftermarket manifold. More likely to run into problems with a cast mani than a proper tubular one.
Nortech is still OEM location
Offline bluo
« Reply #12 on: February 23, 2016, 10:43:17 am »
It appears that way...
I was originally looking at going with a LO4xx turbo and around 450bph but if a stock location turbo is available that'll go right up to 500+ then that may be the way to go?
Offline bluo
« Reply #13 on: February 23, 2016, 10:52:32 am »
What sort of problems?
Offline bluo
« Reply #14 on: February 23, 2016, 10:53:24 am »
You say Nortech is stock location, is that final position of turbo meaning I can maintain the downpipe?
