Author Topic: DIY - Cam Chain and Tensioner Guide  (Read 322104 times)
Offline Paulo P
Re: DIY - Cam Chain and Tensioner Guide
« Reply #30 on: April 18, 2016, 01:25:06 pm »
Worthwhile if you're planning on doing a few then, probably not so much if you only plan on doing it once  :sad1:
Offline Lewo
« Reply #31 on: April 18, 2016, 01:57:05 pm »
Another great guide write up, trouble is I was lost as soon as you got past opening the bonnet  :ashamed:  :smiley:
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=nrk2clruoufpth03s908hberr6&/topic,19740.0.html
« Reply #32 on: April 18, 2016, 02:11:13 pm »
Thanks guys.
I was lost too.... I just loosened a load of bolts and hoped for the best.  :signLOL:
  • -Receive: 692
« Reply #33 on: April 21, 2016, 03:58:36 pm »
Really good guide!  You did quite a few common sense things that I failed to do, like marking the cams with a pen etc  :congrats:
Offline Pesky jones
« Reply #34 on: April 21, 2016, 04:08:48 pm »
The guide that I followed and I believe Dazza followed as well on vortex was good, but this is much more in depth and comprehensive. I reckon you've probably done a lot of people a big favour here rich, well done for taking the time to do it! :notworthy: :congrats:
« Reply #35 on: April 22, 2016, 09:10:12 am »
Thanks guys.
Offline shoaybmakda
  • -Receive: 54
« Reply #36 on: April 23, 2016, 02:17:11 am »
excellent write up - would love to have a go at this..my stumbling point currently is i have the AXX engine and my banjo bolt is quite cross threaded which i know if it comes to it is going to be a pain to take out  :doh:
Offline whitemoredooor
« Reply #37 on: April 28, 2016, 10:02:45 pm »
Thank you for this info and attention to detail, i have these parts on order and will be doing this myself as soon as they arrive  :congrats:
Offline ChazGTI
« Reply #38 on: May 09, 2016, 05:01:53 pm »
Referenced this guide last month and fair play, it's very thorough. Definitely worth the extra effort of removing the battery.
Offline Pesky jones
« Reply #39 on: May 09, 2016, 07:11:47 pm »
Yeah you dont wanna drop that last bolt on the cover
« Reply #40 on: May 23, 2016, 04:09:19 pm »
Ok folks, just stripped down the cam chain cover to find a tenstioner in bits ! also someone has already had a go at this job and the cam adjuster bolt has a very rounded head and i cant get anything on it to remove, can anyone help at all as the tensioner fell to bits and i cant get this back in without removing adjuster, tensioner was glued together  !!! whoever was in this before me needs a slap !
« Reply #41 on: May 24, 2016, 01:27:04 am »
Depending on how mangeled the bolt head is... youll either have to try and use the OEM tool. or drill the bolt out
« Reply #42 on: May 24, 2016, 05:31:05 am »
Got the bolt out with the use of a drill, when re-assembling i needed to rotate the intake cam very slightly, when you did it as i notice on your post that your intake cam was in a different position from when you started, did you have to make any adjustment prior to finishing the job? i have a very slight difference between the marks i made on the cams albeit very little.
Thanks in advance
Offline Pesky jones
« Reply #43 on: May 24, 2016, 08:44:04 am »
Is it all back together @whitemoredooor ?
You can check your timing via VCDS:
Block 91 or in advanced measuring blocks 91-3 & 91-4. These are camshaft adjustment REQUESTED and camshaft adjustment ACTUAL
if AXX - you should see 24KW requested, and +/- 1kw of the requested for actual so 23-25 kw
If BWA and some others (needs checking) - you should see 28KW requested, and +/- 1kw of the requested for actual so 27-29 kw
« Last Edit: March 16, 2017, 08:04:34 pm by Pesky jones »
« Reply #44 on: May 24, 2016, 10:15:47 am »
Providing both cams have rotated by the same amount then it should be fine.
If in doubt turn the engine over twice by hand with a long ratchet on the crank bolt.
