Author Topic: *** All your bluefin/superchips questions and answers in here please.  (Read 167952 times)
Re: Superchips Shakedown Session for me and Greenouse
« Reply #300 on: January 20, 2009, 03:02:47 pm »
I spotted it late last year. I'll see if I can find the thread and post a link. :happy2:
I'll start a new thread too.
« Last Edit: January 20, 2009, 03:06:21 pm by Hurdy »
« Reply #301 on: January 20, 2009, 04:30:20 pm »
Does "fixed gears in Manual mode" mean that she won't shift automatically when near the red zone?
I find S-mode quite useful sometimes exactly because it does shift automatically. Unless I've misunderstood, this could be a backward step!
As for 60% faster shifts, it's not exactly slow as it is , is it.
Offline madman
« Reply #302 on: January 20, 2009, 04:39:17 pm »
A very good read :wink: with sum very good bhp figures :happy2:
Offline joesgti
  • Eat my sick, Eat my sick.
« Reply #303 on: January 20, 2009, 04:42:04 pm »
good write up steve  :happy2:
greenouse's figures are awesome as ever, id love to hear TT's thoughts on them  :rolleye: but i think he has done another dissapearing act for another 6 months  :grin:
would probs make a RR day there, bloody long way away though  :scared:
« Reply #304 on: January 20, 2009, 06:15:19 pm »
^^^^ Jamie's words at SC when he saw the figures for the third time, ' it is what it is'
I'd love to have T_T back but doesn't look as though it's happening in the near future?
Offline Sunglasses Ron
« Reply #305 on: January 20, 2009, 07:17:20 pm »
Steve it is possible to stop the DSG changing down on kick down.. Just keep the up shift paddle pressed down when accelerating and it wont do it mate..  :wink:
Offline SteveP
  • -Given: 117
  • -Receive: 341
    • My Project
« Reply #306 on: January 20, 2009, 08:27:30 pm »
Cheers Ben, I wasn't aware of that  :happy2:
This is the end of this thread, and below is a new one.
« Last Edit: March 04, 2009, 04:25:15 pm by Top Cat »
Re: Ordered Bluefin
« Reply #307 on: January 21, 2009, 02:25:55 pm »
Well I have managed to replicate this. It did require a sustained 'hoofing' through the gears in D. The engine light then flashed for a period of time then stopped. I can't say for sure if this is exactly the same problem however I will be scanning the fault codes as soon as I get home and then a call to Superchips.
As said earlier it sounds as if they have pushed things a bit too far and personally speaking this was not what I wanted when going for Bluefin.
Offline garethmk1
Re: Ordered Bluefin
« Reply #308 on: January 21, 2009, 05:17:05 pm »
Sounds about right - mine usually happens after as you put it a prolonged hoofing ! and I mean WOT in 2nd, 3rd and then up to 4th.  Please post back your DTC's and what superchips tell you - they have prepared a revised map for me that drops power off at the top a little - don't feel that that is a fix.  I also miss the 2nd gear onslaught of the standard ED30 map !
Regards,
Gareth
Mk5 Golf GTi Edition 30 No:- 2101, 3Dr, Tornado Red, Rear Tints, RCD510 & Sound Pack, Arm Rest
Mk1 Golf GTi 16v Helios Blue, Too Many Mods To List .... MY First Car ! Owned Since 1996 !!! NEARLY READY !!!!!
Re: Ordered Bluefin
« Reply #309 on: January 21, 2009, 09:57:58 pm »
Fault codes as requested. I will speak to SC tomorrow.
Wednesday,21,January,2009,18:02:38:57524
VCDS Version: Beta 812.1
                Address 01: Engine
Control Module Part Number: 1K0 907 115 T
  Component and/or Version: 2.0l R4/4V TFSI     0010
           Software Coding: 040300031C070160
            Work Shop Code: WSC 66565
2 Faults Found:
000768 - Random/Multiple Cylinder Misfire Detected
               P0300 - 001 - Upper Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 18028 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 13:07:29
             Freeze Frame:
                    RPM: 6713 /min
                    Load: 100.0 %
                    Speed:  XX.0 km/h
                    Temperature: 84.0°C
                    Temperature: 26.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 14.097 V
000771 - Cylinder 3: Misfire Detected
               P0303 - 001 - Upper Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 18028 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 13:07:29
             Freeze Frame:
                    RPM: 6713 /min
                    Load: 100.0 %
                    Speed:  XX.0 km/h
                    Temperature: 84.0°C
                    Temperature: 26.0°C
                    Voltage: 14.097 V
Readiness: 0000 0000
Offline gazbutS3
Re: Ordered Bluefin
« Reply #310 on: January 22, 2009, 11:32:28 am »
I'm sure these are the same codes some lads with Revo have got/had
Re: Ordered Bluefin
« Reply #311 on: January 22, 2009, 11:34:19 am »
I spoke to them this morning and probably got the same response as Gareth.
Anyway I have downloaded the new map and I will be trying it out at lunchtime.
I am going to try and do some logs before I swap and after if the weather holds out.
Offline 182_blue
  • -Receive: 54
Re: Ordered Bluefin
« Reply #312 on: January 22, 2009, 11:41:19 am »
so the new map cuts the power a little at the top end ?
Re: Ordered Bluefin
« Reply #313 on: January 22, 2009, 12:00:41 pm »
Thats what the guy I spoke to said and to be honest I would prefer that.
As soon as I get the opportunity I will generate some logs and post them up. :smiley:
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
Re: Ordered Bluefin
« Reply #314 on: January 22, 2009, 02:16:57 pm »
RPM: 6713 /min  :laugh:
whats the limiter? 6800? good to see you are 'using' your car  :happy2:
Keep us informed, Im interested to see what they say theyve done , good luck
Red ED35 5dr DSG
BLOG | BUILD
