Author Topic: Does 2 x Flat tyres in 18 months seem a little much to you?  (Read 1808 times)
Offline ghuk
« on: October 10, 2016, 08:56:44 pm »
Hi guys
Would appreciate your thoughts on flat tyres. After passing my test way back in 1993 I've owned and driven various makes of cars (Peugeot 306 Cabriolet, Peugeot 206 GTI, Honda Civic Coupe V-Tec, VW Bora TDI & Jag X-Type). Between then and up to when I bought my Mk5 Golf GTI in mid 2015 I've probably had 3 tyres fail on me in a 22 year period.
However since changing to my Golf, in the last 16 months I've had 2 fail. The first was about 4 months ago when I hit a pothole, as a result the alloy buckled and I had to purchase a new wheel + tyre. Today though I was driving to work behind an OAP in a Micra doing 35mph in a 60 and the next thing I know the front left tyre goes bang. I thought I had hit another pot hole but I drove home the same way and I couldn't see any on the tarmac where it happened
Suffice to say I spent the next 90 minutes waiting to be rescued as it turned out by a very helpful young man from Green Flag.
I'm not sure if its just bad luck, the sports suspension on the Golf GTI or the tyres I have fitted on the car. They're Dunlop Wintersport 3D's with reinforced side walls. I'm beginning to think they are unsuitable on the country lanes I have take to get to work and maybe a change is in order. They're certainly not cheap either, in fact looking online a new pair will cost me the best part of £300 fitted and balanced. As winter is soon upon us though I'm reluctant to go with 4 new summer tyres. It would be just my luck to change to summer tyres and we then get a stack load of ice & snow.
Any thoughts would be much appreciated
George
« Last Edit: October 10, 2016, 09:00:46 pm by ghuk »
2005 Golf GTI Mk5
Offline Frodo-anni
  • -Receive: 45
Re: Does 2 x Flat tyres in 18 months seem a little much to you?
« Reply #1 on: October 10, 2016, 09:16:23 pm »
Seems very early to be on winters, still 10-16c here in Yorkshire. Registered at 9c this morning at 0530. I only fit my winters when the temps stay below 7c for the times of my commute.
mk5 GTI Edition 30 DSG No0391
Offline Dave J
  • -Given: 45
  • -Receive: 63
« Reply #2 on: October 10, 2016, 10:02:51 pm »
In honesty, it just sounds like bad luck to me. You might have hit a nail or something else that had bedded itself into the tyre over time without you knowing. Any feedback from the tyre fitters when swapping out the tyre for a new one, or are you still waiting to have it changed?
Fair play to you for changing to winter tyres - I've thought about it for mine, but winter doesn't seem to be too harsh in the SE...
Edition 30 - no. 1387
Offline ghuk
« Reply #3 on: October 10, 2016, 10:31:44 pm »
Cheers guys
I'd love to be able to claim for changing to winters but they actually came with the car when I purchased it last year! I've massively cut down on the amount of miles I do each month and as all 4 tyres were brand new when I bought the GTI I didn't want to change them straight off.
Now with the cold months looming and quite a lot of tread left on the rears I'm torn between making a fresh start with 4 new tyres, or, replacing the fronts with 2 new winters and changing all 4 to summers later in 2017. Wish I had 2 sets of alloy wheels as that would make things a lot simpler  :happy2:
Hope that explains things a bit better
George
« Last Edit: October 10, 2016, 10:33:36 pm by ghuk »
2005 Golf GTI Mk5
Offline xs2man
  • -Given: 18
« Reply #4 on: October 11, 2016, 09:13:02 am »
It is way to early really to be wearing winter rubber on your car.  Surely you must have felt the lack of traction in the warmer months?  Unless you are driving miss daisy, in which case, why drive a GTI, you loose a lot of performance with winter tyres in warmer weather.  Plus you generally rip through winter tyre tread when its warmer.
You COULD change all tyres to the likes of Michelin Cross-Climate tyres, which are meant to be very good in both summer and winter.  You will loose a bit of performance against summer tyres in the summer, and the same against winter tyres in winter, but then you only need to run one set of wheels.  But presumably you still have 3 good winter tyres, and you could sell them to recoup some money.
I would, personally though, change all the tyres to summer tyres, and buy a second set of wheels (second hand) for the winter tyres (or keep these wheels for winter and get new summer wheels).  Although you are just about ready for winter tyres now, it's still not quite there.  So it would make sense to keep summer rubber just now, as winters wouldn't really be needed for a couple months still.  The advantage with running 2 sets of wheels is that it doesn't cost you fitting and balancing twice a year to swap the tyres over.  And if you buy the wheels second hand, they will, for the most part, always be worth roughly what you paid for them, if you sell them when you sell your car.  Then, you use the winter tread in the winter, and summer tread in the summer, saving both sets of tyres in the months where they are not suitable.  This is, of course, assuming you have somewhere to keep a second set of wheels (I know not everyone does).
Otherwise, you could just put the winter back on just now, and look to getting summer rubber all round later, around March / April.
Surely you only need to replace one tyre though, rather than a pair?  Especially if you just replaced one of the tyres a few months ago, and don't do a huge amount of miles?  It must still be almost new, and so would match up well with the new tyre.  No need to change the pair.  And £300 seem a bit much for a pair too.  Assuming they are 225/40/18, they are just over £100 from Camskill (http://www.camskill.co.uk/m11b0s1316p130034/Dunlop_Tyres_Winter_Snow_Car_Dunlop_WinterSport_5_Dunlop_Winter_Sport_5_-_225_40_R18_92V_XL_MFS_TL_Fuel_Eff_%3A_E_Wet_Grip%3A_B_NoiseClass%3A_2_Noise%3A_71dB), and shouldn't be much more than £10-15 for fitting and balancing.
