Author Topic: Decat to standard system?  (Read 3424 times)
Offline seanieb
« on: October 23, 2017, 08:50:18 pm »
Is a full system really needed or would just the highflow downpipe fitted to standard system get the same results after remap?
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=riduq8jn69dlcepj47jok12bo6&/topic,19740.0.html
Re: Decat to standard system?
« Reply #1 on: October 23, 2017, 09:26:35 pm »
It depends on what results you are after.
Offline seanieb
« Reply #2 on: October 24, 2017, 06:32:03 am »
I know standard stage 1s tend to make around 240-250hp so would a downpipe and cai make 15-20 more?
« Reply #3 on: October 24, 2017, 07:31:54 am »
It has the potential too but you’ll run out of fuel between 250-260 so you would probably need an upgraded fuel pump (and upgraded intercooler and intake) if 270bhp is your target
Offline Paradox1
  • -Given: 41
« Reply #4 on: October 24, 2017, 10:08:11 am »
off topic, what calipers are those in your sig?
« Reply #5 on: October 25, 2017, 01:29:44 pm »
DB9. Same as TTRS
Offline AJP
  • -Given: 392
  • -Receive: 317
« Reply #6 on: October 25, 2017, 03:29:09 pm »
X2
Mine made 270 on the R-Tech rollers, just with a full BCS exhaust and Pipercross panel filter. But it put the standard fuel pump right on the limit - fuel cuts were just round the corner. Loba pump sorted that and also made it a much nicer car in terms of power delivery.
Bottom line - if you want a strong and reliable 270bhp from a k03 TFSI, get an uprated pump.
  • -Receive: 692
« Reply #7 on: October 25, 2017, 03:47:00 pm »
Same applies to the K04 engines.  The crazy midrange torque the TFSI engines are capable of is only possible with an uprated HPFP.
