Author Topic: Timing issue  (Read 1170 times)
Offline norman1979
Timing issue
« on: February 18, 2018, 12:16:37 pm »
I am having some issues with my sat nav, and I tried to pull out a fuse from the engine side fuse box. I did this with the car running and I pulled out the fuel pump relay fuse (you plonker Rodney!).
That caused the car to misfire abit then I stuck the fuse back in. Since then, there has been a loud sound around 1k revs similar to a diesel which tails off with higher revs.
On vagcom this comes up as a P0011 camshaft timing advanced retarded. Cleared the code and it comes up again
Anybody know what damage I have done?
Offline norman1979
Re: Timing issue
« Reply #1 on: February 20, 2018, 08:25:21 am »
Bump. Any help?
