Author Topic: Mounting new tweeters  (Read 1891 times)
willni
« on: June 27, 2018, 11:42:17 pm »
Anyone have any tips on fitting new tweeters to the door cars, I've mine installed but not 100% happy and want a stronger mount to the doorcard, had no luck with plastic welding.
Offline Octoparrot
  • -Receive: 104
Re: Mounting new tweeters
« Reply #1 on: June 28, 2018, 08:23:52 pm »
Hi, do you mean the mid speaker on the door card or the tweeters by the door mirror? I retrofitted the mid speakers as mine didn't originally have them. I created an adaptor plate out of a sheet of plastic I got from eBay, mounted the aftermarket speaker to it and then screwed it to the door card using the existing mounting points using screws and clips from halfords.
Offline Christiank
  • -Receive: 39
« Reply #2 on: June 28, 2018, 09:29:48 pm »
Buy 2 new doorcords from allegro.pl or from ebay that will fit the speaker setup you need :)
willni
« Reply #3 on: June 30, 2018, 10:12:37 am »
It's essentially the mids, but in the 5 door the rears have tweeter, where the mids are in the fronts. Would the screws not go through the door card though?
Offline Octoparrot
  • -Receive: 104
« Reply #4 on: June 30, 2018, 10:37:59 pm »
No the mounting points are deep enough if the correct length screws are used, when you remove the door card it will become obvious.
