Author Topic: Fault code po441  (Read 4115 times)
Offline Lewis0292
Fault code po441
« on: July 21, 2018, 03:05:29 pm »
Hi I just purchased a ed30 last week and has been running fine until yesterday ... started revving to neally 2000rpm at idle so plugged it in and getting fault code po441 (incorrect purge flow) would this cause it to be revving itself as I’ve read that it could be n80 valve or charcoal canister ?? Thanks
Offline Leco_GTI
Re: Fault code po441
« Reply #1 on: July 21, 2018, 06:25:55 pm »
I have the same problem since I bought the car almost 2 years ago. Replaced the N80 valve but it didn't resolve the problem. I didn't bother replacing the canister since the car runs fine and it doesn't cause any harm running the car with this "problem".
Offline Dave J
  • -Given: 45
  • -Receive: 63
« Reply #2 on: July 21, 2018, 07:18:59 pm »
Mines never done that, but it used to throw up the P0441 code every so often and an occasional EML. It used to go away with no issues, and from the info on here it was down to the charcoal cannister & brimming the tank with fuel. I replaced my cannister and the N80 valve and it has been perfect ever since. I've read that others solved the problem by not filling the tank to the top.
Edition 30 - no. 1387
Offline Lewis0292
« Reply #3 on: July 21, 2018, 07:23:48 pm »
Cheers guys will just have to get to the bottom of it revving at idle now
Offline Rossimac
  • -Given: 78
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,90767.0.html
« Reply #4 on: July 22, 2018, 09:13:51 am »
Same as above.
Tank was about £90 from VW. I think others have gotten much cheaper Chinese clones from eBay that do the same job. Up to you.
Offline muff1991
  • -Receive: 70
« Reply #5 on: July 28, 2018, 11:51:37 am »
Doesn’t the coolant temperature sensor play a part with idle revs rising etc?
  • -Receive: 692
« Reply #6 on: July 28, 2018, 06:03:10 pm »
The high revs sounds like an air leak to me.  Maybe the N80 valve is stuck open and the other end of the tube is open to air.
The easiest way to check your evap circuit is working correctly is to listen for a 'whoosh' pressure relief noise when unscrewing the petrol cap, when the tank is nearly empty.
If you don't get that noise, the evap circuit has a leak to atmosphere somewhere, or the N80 valve is stuck open.  Quite common.
Brimming the fuel tank is not an issue with a nicely sealed evap circuit, that's a myth.
Fixing it once and for all does usually entail a new N80 and a new carbon can in a lot of cases.   The carbon can breaks down over time and little charcoal pellets can get sucked into the N80 valve, causing it stick open.
