Author Topic: dab aerial  (Read 1602 times)
Offline mr lobitos
dab aerial
« on: July 29, 2020, 05:57:07 pm »
hi everyone,  back in an ed after doing a swop with my mk4 r32,  question is have fitted an rcd510 dab but can't get a signal with the dab. I already had a dab windscreen mount aerial , so fitted that but the connection on it was not fakra, so ordered an adapter from tps, fitted that but still no joy,  the aerial connector on the back of the headunit has a tiny brass thing in it , this seems to be stopping the fakra fitting flush with the back of the headunit, is this correct .  is there a better aerial to use , thanks in advance
Offline terrier
  • -Receive: 41
  • My Ride: GTI now gone
Re: dab aerial
« Reply #1 on: July 29, 2020, 06:55:20 pm »
6R0 035 501D
Offline mr lobitos
Re: dab aerial
« Reply #2 on: July 29, 2020, 07:12:26 pm »
thanks for reply,  do you know if that comes with the lead to attach to the headunit ?
Offline terrier
  • -Receive: 41
Re: dab aerial
« Reply #3 on: July 29, 2020, 07:49:22 pm »
No lead unless you can find someone selling both together on ebay. Try "dabonwheels" "connects2" plus others
Offline mr lobitos
Re: dab aerial
« Reply #4 on: July 29, 2020, 07:56:51 pm »
thanks again,  can you not buy one from tps ?
Offline terrier
  • -Receive: 41
Re: dab aerial
« Reply #5 on: July 29, 2020, 08:21:22 pm »
not sure they will still have stock but certainly worth a call
