Author Topic: GFB boost tap question  (Read 21261 times)
Offline GVK
  • -Receive: 76
    • GVKmotorsport
« on: June 20, 2021, 10:36:15 pm »
Anyone used the GFB boost tap  (I'm fitting a boost gauge) on a mk5 TFSI? I've ordered one but was thinking how does it actually secure in the manifold, looks like a pair of o-rings. My car has a BSH PCV delete so the pipe isn't there to go on the end of the boost tap.I don't want the thing flying out the first time it comes on boost!
https://www.demon-tweeks.com/gfb-boost-tap-vag-mk5-mk6-2-0-tfsi-gfb5800/?istCompanyId=a2904180-3a7d-4e56-b876-cf81c9512180&istFeedId=6fbc4b04-fd28-4ce1-8513-835c8f118690&istItemId=wptpptwtq&istBid=t&gclid=CjwKCAjwzruGBhBAEiwAUqMR8GIZU3dALab2VrWvxXrluolSyQn6Mku-lGjM2M-Ewau0kZU4VUeMARoCvNQQAvD_BwE&gclsrc=aw.ds
Offline Trav Turbo
  • -Given: 18
Re: GFB boost tap question
« Reply #1 on: June 20, 2021, 10:45:55 pm »
It fits on the end of the inlet manifold there is a slot cut out on the boost tap that when pushed on turn it until it slots in place on the inlet manifold secured. If your running a pcv delete I think I've seen one blanked off on the end where the pipe would go to the breather, hope that makes sense.
Sent from my SM-N950F using Tapatalk
Offline GVK
  • -Receive: 76
    • GVKmotorsport
« Reply #2 on: June 20, 2021, 10:50:26 pm »
Yes, mine is blocked off with a plastic cap where the pipe from pcv would usually go.  :happy2:
Offline Trav Turbo
  • -Given: 18
« Reply #3 on: June 21, 2021, 12:34:09 pm »
Use the same plastic cap on the boost tap should be ok
Offline GVK
  • -Receive: 76
    • GVKmotorsport
« Reply #4 on: June 21, 2021, 12:58:26 pm »
Yup, I guessed that.  :happy2:
  • -Receive: 692
« Reply #5 on: June 26, 2021, 01:08:45 am »
I would recommend this stepper motor gauge tapped into one of the blanked off holes in the intake manifold.  Matches the blue/red OEM lighting and way more accurate/quicker responding than a long vac line fed to a mechanical gauge.  I used this one on my VR6 Turbo and the peak boost recall button was a nice touch.
https://www.merlinmotorsport.co.uk/p/spa-professional-boost-pressure-gauge-1-to-2-5-bar-bp-1-25
Offline GVK
  • -Receive: 76
    • GVKmotorsport
« Reply #6 on: July 06, 2021, 01:36:53 am »
Already got the newsouth matching gauge from bar tek Germany.
https://www.bar-tek-tuning.com/boost-gauge-newsouth-performance
« Last Edit: July 06, 2021, 02:53:55 am by GVK »
Offline Sheridan_C
  • Newbie
« Reply #7 on: March 17, 2026, 09:00:15 pm »
Did you get it installed in the end? Can u send a pic of where you fitted it
Offline GVK
  • -Receive: 76
    • GVKmotorsport
« Reply #8 on: May 10, 2026, 08:43:40 pm »
Sorry for late reply didn't take any pics of the boost tap fitted. sorry! Here's a pic of gauge though
« Last Edit: May 10, 2026, 08:54:05 pm by GVK »
