Author Topic: Black Pirelli DSG  (Read 11415 times)
Offline Twistedandy
Black Pirelli DSG
« on: July 21, 2021, 09:45:47 pm »
Had this a couple of weeks now, really like the balance of the car.
2009 Black Pirelli DSG
Offline Twistedandy
Re: Black Pirelli DSG
« Reply #1 on: July 21, 2021, 09:52:39 pm »
Added the wind deflectors.
Changed the internal and some external lighting to white LED
Added a DAB dongle but will need to change the shark fin for one that supports DAB
Had countless issues with the Bluetooth mic, volume is really low and badly distorted.
Added an iPhone charging cable behind drivers side vent and slapped on a phone cradle
Need to sort out a scuffed DSG base plate, I think it’s quite normal to have a scuffed one 😀
Offline GVK
  • -Receive: 76
    • GVKmotorsport
« Reply #2 on: July 22, 2021, 03:50:40 am »
Nice car.
Sent from my Pixel 4a using Tapatalk
Offline Twistedandy
« Reply #3 on: August 09, 2021, 06:24:17 pm »
Sorted out the scuffed DSG base.
Offline Twistedandy
« Reply #4 on: August 09, 2021, 06:25:16 pm »
I have changed the main light switch as the flange was cracked.
Offline Twistedandy
« Reply #5 on: August 09, 2021, 06:31:20 pm »
Looks like I have a thermostat problem, in that it’s always open. It takes too long for the temperature to rise and it will fall at motorway speeds. It will only get to 90C when it’s idling. I’m hoping I can get this repaired under warranty. I’ll advise further once known.
I’d also like to replace the shark fin for one that includes DAB as I am unhappy with the drop out rate after using an amplified signal splitter on the FM/AM fin.
I have also booked in locally to wrap the front lip and to have the brake calipers repainted. I managed to kerb an alloy at the weekend, gave myself an arse-kicking….
Offline Twistedandy
« Reply #6 on: August 09, 2021, 06:33:18 pm »
Tonight’s job, as it’s resembling a monsoon outside is to replace the front windscreen wipers, I managed to get Bosch aero for half the price our local Halfords wanted, from Amazon.
Offline Twistedandy
« Reply #7 on: August 09, 2021, 06:34:47 pm »
I launched the car a couple of times this weekend - it’s a lot of fun and I was trying to get some experience to reduce the initial wheel spin. Any tips appreciated.
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #8 on: August 18, 2021, 05:18:18 am »
Don't use launch control. Just feed in the throttle progressively. Upgrade the front control arm rear bushes with anti-lift bushes and fit a dogbone insert bush to reduce engine movement.
Offline Twistedandy
« Reply #9 on: August 26, 2021, 07:43:39 am »
Car is just back from the garage having had the thermostat replaced, now the temp sits at 90C 😀 the PCV valve was done at the same time…together with a regas on the AC…..now I have it back I can restart some mods.
Offline Twistedandy
« Reply #10 on: August 26, 2021, 07:45:28 am »
Thank you, I’ll take a look at those bushes…
Offline Twistedandy
« Reply #11 on: August 26, 2021, 07:47:11 am »
And it needs a thorough clean inside and out.
Offline EnglandUK
« Reply #12 on: September 01, 2021, 11:42:03 am »
Lovely Pirelli, always here a soft spot for these.
Offline Twistedandy
« Reply #13 on: September 23, 2021, 05:58:23 pm »
Freshened up the front as the red beading was badly faded and went for sunshine yellow. Included the bottom lip and I think it looks fresh. Will get to the brake calipers for painting before the weather breaks - I hope.
Offline Twistedandy
« Reply #14 on: September 23, 2021, 06:14:22 pm »
Working on a reverse camera addition at the moment. Taking the inner trim off was done carefully, I’m hoping it’ll go back on just as easily.
I’ve mounted a small camera just above the rear licence plate and run the cable through a hole I drilled in the bumper behind the licence plate. The wires then run through a hole into the boot and I’m currently running a 12v live from the rear 12v socket for the relay. I’ve yet to find the live feed to the reverse light but have the trim off so shouldn’t take me too long. Planning to complete the wiring at the back end before running the RCA cable to the head unit..
