Author Topic: traction control light  (Read 13169 times)
Offline davidjonknight
« on: November 15, 2022, 05:56:18 pm »
So once again the car has failed its MOT. All to do with the Traction control light not going out on the dashboard. there were two lights on originally. the steering wheel light and the car on the wiggly road. Doing the steering wheel to the left and then to the right made the steering wheel light go out but not the car icon. ODB11 throws up a Steering angle sensor error.'mechanical malfunction. fault code 00778
Offline GVK
  • -Receive: 76
    • GVKmotorsport
Re: traction control light
« Reply #1 on: November 15, 2022, 07:38:26 pm »
http://wiki.ross-tech.com/wiki/index.php/00778
00778 - Steering Angle Sensor (G85): Mechanical Failure
Possible Causes
    Steering Angle Sensor (G85) Basic Setting lost
    Steering Angle Sensor (G85) Installation Position incorrect
    Suspension Geometry incorrect
Possible Solutions
    Perform Steering Angle Sensor (G85) Basic Setting
        See Vehicle specific Diagnostic Procedures for Details
    Check Steering Angle Sensor (G85) Installation Position
    Check Suspension Geometry
« Last Edit: November 15, 2022, 07:46:20 pm by GVK »
Offline GVK
  • -Receive: 76
    • GVKmotorsport
« Reply #2 on: November 15, 2022, 07:59:07 pm »
http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Steering_Assist#Sensor_for_Steering_Angle_.28G85.29
This explains in full detail about the basic settings you maybe able to do it on OBD11, but the ross tech page is for VCDS ideally
Offline Corish
« Reply #3 on: November 20, 2022, 09:41:56 pm »
You want to be making sure you have 4 equal wheel speeds, it won't initialize the angle sensor until you do a short drive in a straight line and it is important the wheel speeds match. 1kph difference in the values won't be an issue, but if you've a bad exciter ring on the bearing it will fluctuate too much.
Check measuring blocks 1 in ABS.
Offline Lightynolikey
« Reply #4 on: October 16, 2025, 08:47:33 pm »
Was there an outcome to this please?
What if the wheel speed sensors were OK?
Offline rxpx69
« Reply #5 on: December 08, 2025, 01:28:40 am »
You'll need to replace the ABS pump, had the same issue, the amber steering light is very difficult to go out when you have the solid EPS light on, think I did a 50 mile trip and it randomly went off. I had to replace my ABS pump in the end to resolve the ESP light stuck on issue, once replaced the amber steering light will go out after a full turn to the left then right after 20-30 seconds.
Same error codes.
