Author Topic: Some Help Broke Down :(  (Read 14958 times)
Offline GVK
  • -Receive: 70
    • GVKmotorsport
Re: Some Help Broke Down :(
« Reply #15 on: August 26, 2023, 11:46:19 pm »
Just for a compression test I wouldn't bother with the coolant/fuel lines if they are all off , I would disconnect the fuel pump under the rear seat. You'll only need to crank the engine for 5-10secs each cylinder.
Put the mount back on with a couple of bolts.
  • -Receive: 691
« Reply #16 on: August 27, 2023, 11:55:20 am »
Oh dear.  15 teeth off is quite likely to have resulted in the valves getting intimate with the piston(s).  A compression test when it's retimed will confirm.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=kv4vlv5lq1ie28990foofgjqhh&/topic,90967.msg917089.html#msg917089
« Reply #17 on: August 27, 2023, 01:42:48 pm »
The cam sprocket is 2 teeth away from the mark but when I try and line it up it springs back to 2 teeth away.
Now it's sprung forward a quarter turn..
Going to take the valve cover off.
« Last Edit: August 27, 2023, 02:17:41 pm by dazza »
05 | Tornado Red | DSG
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #18 on: August 27, 2023, 10:58:24 pm »
I started to remove the head. But I was thinking maybe it would have stayed at tdc if I removed the plugs?
What should I be looking for now the rocker cover is off?
Offline GVK
  • -Receive: 70
    • GVKmotorsport
« Reply #19 on: August 27, 2023, 11:17:18 pm »
I'd remove the cams and check the rocker arms that are under the cams for cracking/damage, then remove the head and check for bent valves, you may see that some of the valves aren't sitting right with the cams out.
  • -Receive: 691
« Reply #20 on: September 01, 2023, 08:21:57 pm »
At TDC, the rounded notches in the cams should both be horizontal and all 4 cam lobes on cylinder 1 pointing up.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #21 on: September 04, 2023, 06:05:35 pm »
Been away for a few days, all i could think about was cracking on with this  :confused:
Removed the heat shield, whats the best approach for removing the exaust manifold? The haynes manual said i need to remove the turbo?
Thanks again for all your help.
Offline Octoparrot
  • -Receive: 104
« Reply #22 on: September 04, 2023, 07:04:28 pm »
The turbo is integral with the exhaust manifold.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #23 on: September 04, 2023, 07:38:15 pm »
So i need to remove the turbo or i can just unbolt it from the head and leave it in place?
Offline Octoparrot
  • -Receive: 104
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
Offline Octoparrot
  • -Receive: 104
« Reply #26 on: September 08, 2023, 05:06:07 pm »
Probably easier to remove the head with the turbo detached from it.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #27 on: September 08, 2023, 05:17:01 pm »
The pelican part tutorial said it may be easier to remove the turbo first but this looks like a pita. Can I not just disconnect the manifold from the head and leave it where it is?
Offline Octoparrot
  • -Receive: 104
« Reply #28 on: September 09, 2023, 12:24:20 am »
Try it, it can't hurt..
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #29 on: September 09, 2023, 08:09:59 pm »
everything is now removed from the head  :laugh:
anyone know the correct tool to remove the head bolts? I bought one but it did not fit  :sick:
