Author Topic: Some Help Broke Down :(  (Read 27937 times)
Offline GVK
  • -Receive: 76
    • GVKmotorsport
Re: Some Help Broke Down :(
« Reply #30 on: September 09, 2023, 08:20:20 pm »
Done a bit of Googling , it appears to be a 10mm Ribe socket, which looks like a torx but has squared off edges.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=qifg2qegk8dckqt1ql8v8e7p4s&/topic,90967.msg917089.html#msg917089
« Reply #31 on: September 09, 2023, 08:52:55 pm »
Thanks mate.
I just bought one off amazon for delivery tomorrow, When i did my cam chain i snapped a cheap one of these and then bought the original vw tool.
Hopefully it will not snap again.
05 | Tornado Red | DSG
Offline GVK
  • -Receive: 76
    • GVKmotorsport
« Reply #32 on: September 09, 2023, 09:08:12 pm »
Fingers crossed Dazza, do the bolts look like I described?
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #33 on: September 09, 2023, 09:30:40 pm »
Yes its a ribe socket I have a set of these but they are too short. Will let you guys know how i get on tomorrow  :scared1:
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #34 on: September 10, 2023, 05:39:09 pm »
The head is off. Some pics.
Offline GVK
  • -Receive: 76
    • GVKmotorsport
« Reply #35 on: September 10, 2023, 07:42:47 pm »
Can see the valve to piston contact on top of the pistons!
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #36 on: September 10, 2023, 08:34:27 pm »
this?
Also all the intake valves have some skuffed spots.
Offline GVK
  • -Receive: 76
    • GVKmotorsport
« Reply #37 on: September 10, 2023, 08:41:30 pm »
Yep - Are the cams out of the head? If so put some petrol around the valves to see which ones leak.
Can see most of the inlet valves are bent from the pics but they all need removing to check properly
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #38 on: September 10, 2023, 08:57:04 pm »
I have not taken the cams out. Can this be done without removing the cam adjuster? I lent my locking tool and socket to some members and never had it back  :sad1:
Offline GVK
  • -Receive: 76
    • GVKmotorsport
« Reply #39 on: September 10, 2023, 08:59:04 pm »
Not sure as never done the job on a TFSI personally.
They'll need removing and the rocker assemblies checking for damage too.
« Last Edit: September 10, 2023, 09:30:33 pm by GVK »
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #40 on: September 12, 2023, 05:40:34 pm »
Not having much luck with this locking tool will not fit
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #41 on: September 12, 2023, 08:31:37 pm »
The cams are out will have to remove the cam adjuster another day.
The lifters look good
Offline GVK
  • -Receive: 76
    • GVKmotorsport
« Reply #42 on: September 12, 2023, 10:23:21 pm »
Just the valves to remove now then Dazza! :congrats:
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #43 on: September 13, 2023, 07:07:19 am »
What tools will I need to get these valves out?
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
