Author Topic: Help please for cooling issues  (Read 13109 times)
Offline Beanbox19844
« on: August 24, 2025, 09:56:50 pm »
Evening all
So ive got an issue with my car as the large fan is running from the moment you start the car up. Ive used my obdeleven reader and that's showing a P2185 code being temp sensor 2 too high. Looking at the live readings its showing the radiator outlet temp is minus 40.
So far ive done the following
Changed both sensors
Thermostat was replaced 6 months ago
Checked the wiring for continuity and that's showing 1.6ohms
Does anyone on here have any other suggestions what it could be?
Thanks everyone
Offline jonnd
Re: Help please for cooling issues
« Reply #1 on: October 29, 2025, 10:07:27 pm »
Having the same issues here now - 45c on the radiator coolant did you fix it?
Offline jonnd
« Reply #2 on: December 06, 2025, 07:09:17 pm »
Check the plugs i had mine broken by the gearbox (auto) wires break easy as there really thin
