Author Topic: 2.0 TDi BKD sticking turbo vanes  (Read 11211 times)
Offline Ricky123
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,98436.0.html
« on: October 01, 2025, 07:09:46 pm »
Evening all…
Has anyone had any experience with sticky turbo vanes?
I’ve Bought a cheap GT sport 140bhp to run around in and it has all the usual symptoms of sticky vanes, I was wondering if anyone can shed some light on budget solution to it without having to buy a new/recon turbo?
And does anyone no if I replace the turbo nozzle ring with a new one then can the turbo just be refitted and it will work/perform as it should or will it need “setting up” after?
59 red mk6 GTi 5dr
57 mk5 1.9 TDi match
22 a3 s-line competition 45 tfsiE
09 Suzuki GSXR 1000 (road going track sl*g)
Offline MKVASMR
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=fiuh821eq32dblcl034c5t0t3a&/topic,134365.msg1165175.html#msg1165175
Re: 2.0 TDi BKD sticking turbo vanes
« Reply #1 on: October 01, 2025, 10:45:58 pm »
Those are pretty easy to pull apart and clean. Other than that give her the beans as much as you can. And I mean the turbo you don't have to be going fast just a lot of aggressive 2nd gear pulls
Offline GVK
  • -Receive: 75
    • GVKmotorsport
« Reply #2 on: October 02, 2025, 10:51:05 pm »
I did remove and clean a VNT 1.9 TDI turbo years ago that had sticking vanes on a Ford Galaxy with the VAG 1.9 lump , nothing needed setting up.
