Author Topic: Power folding mirror modules.  (Read 18051 times)
Offline GTI 500
« on: October 02, 2025, 10:36:41 pm »
Bought some power folding mirrors for my 2005 GTI (from a 2006 car), can someone confirm if these are compatible for my car & if they can be coded to fold on the key & when the car is locked.
module numbers, motor numbers 1K0 959 701L & 702L,
Black module numbers 1K0 959 792H & 793H,
Any info would be great.
Offline ZoliWorks
Re: Power folding mirror modules.
« Reply #1 on: October 04, 2025, 12:24:48 am »
Here's a list of all door controllers and what they are. I dont remember which PN is pre or post 2007 anymore since it's been a while since I worked with them but I dont think they did any gen 1's and 2's post 2007. Gen 2 high should be pre 2007 and support power folding.
The ones you got should support power folding but to get them to fold in/out by locking the car? I think you need mk6 modules for that. And if your car is pre 2007, good luck with the wiring!
Mk5 Jetta 2.0 TFSI BWA | Manual | Mk6 GTI Front | BorgWarner K04 Turbo | Sachs X-Tend Clutch Kit | Ta-Technix Air Intake | Milltek Catless Resonated Exhaust | Ta-Technix Sandwich Intercooler | OEM S3 Injectors | Vis Motorsport 175 bar HPFP | 319hp 491nm
Offline GTI 500
« Reply #2 on: October 07, 2025, 10:00:51 pm »
That's great thank you.
Offline GTI 500
« Reply #3 on: October 11, 2025, 05:57:54 pm »
OK, so fitted the Power folding mirrors today, all working as they should without having to code them in, does that sound write or should i  go inti VCDS and press the "do it " button even though they work??
Offline ZoliWorks
« Reply #4 on: October 12, 2025, 03:54:49 pm »
I'd go into VCDS just to look through all the options there and make sure it's coded according to your specs.
