Author Topic: Ignition stuck  (Read 13052 times)
Offline Jons1001
  • -Given: 22
Ignition stuck
« on: November 24, 2025, 06:06:31 pm »
Hi all,
As above having problems with the ignition being stuck, takes a lot of wiggling the key and wheel at the same time to be able to start the car. Will it be a new barrel I need or will there be something else potentially? Any way to know for sure without stripping it all?
Also do you think I can get away with aftermarket? Car is a 2008 mk5 gti.
Offline skkane
Re: Ignition stuck
« Reply #1 on: November 27, 2025, 04:42:17 pm »
Yup, it's know to happen on VW's, many broken keys and ppl getting stuck in some remote area. Just had mine changed a few days ago, aftermarket one, guy came home, 130 GBP and 40mins later fixed and smooth as butter (this is EEU prices so expect more in the UK I guess). You'll need a new barrel and keys recoded if you don't have Immo off I think.
2007 ED30
Offline Jons1001
  • -Given: 22
Re: Ignition stuck
« Reply #2 on: November 29, 2025, 03:01:29 pm »
Cheers, I rang a local auto locksmith and they were saying I need to have the door locks changed aswell, do you know if this is needed?
Offline Kakashicoc2015
Re: Ignition stuck
« Reply #3 on: December 02, 2025, 12:34:27 am »
I had same issues. Had Ignition barrel replaced. Did not need new keys.
Lowest quote I found (London) was £250 with 6 months warranty. Used a new part.
If you are based in London, you can reach out to my locksmith Muhammad on 07752548020. Decent fella.
Offline skkane
Re: Ignition stuck
« Reply #4 on: December 04, 2025, 12:55:12 pm »
Not needed for mine. They're probably thinking you'll get new keys and they won't match the door locks or something of that nature. I just replaced the barrel and am using my existing keys.
2007 ED30
Offline Jons1001
  • -Given: 22
Re: Ignition stuck
« Reply #5 on: December 09, 2025, 07:04:24 am »
Cheers both. I have swapped the ignition housing (not a nice job at all) and what I did in order for my old key to be able to do both the ignition and the door is take the old lock cylinder and fit it to the new ignition barrel. The key now turns freely and car now starts fine but I have an issue.
The remote fob doesn’t work and also when I turn the ignition off the radio and lights stay on  :doh:
My first thought was the ignition switch, the new housing came with an ignition switch already attached but this housing is not a genuine part so wondering if it is faulty in some way.
Any other suggestions?
