Author Topic: Need someone to fix leak in car  (Read 6757 times)
Offline Simonsach
  • Newbie
« on: December 06, 2025, 03:04:36 pm »
I’ve a soaking wet drivers floor. Watched countless videos. Had roof lining off and checked all pipes. Had rubber hoses out, cut, cleaned and replaced. Had windscreen wipers off and checked for blockages. Still leaking. Need a local garage to fix. Any recommendations near Portsmouth/Southampton
Offline Gull
Re: Need someone to fix leak in car
« Reply #1 on: December 08, 2025, 11:38:05 am »
Maybe a bit more history is needed?
Is this a new to you motor with a pre-existing problem or has it just suddenly started leaking?
If it's just started leaking, can you think of anything that has changed?
Have you tried drying it out, then jet washing it in various places until it leaks?
It may sound daft, but have you had a windscreen replacement? I heard some story about autoglass having a bunch of screens which had the fitting markers in slightly the wrong place which meant they would end up leaking but it's not an obvious place to check.
Offline mjmallia
  • -Receive: 60
« Reply #2 on: December 08, 2025, 03:41:38 pm »
Is the windscreen genuine or a replacement, as a replacement may possibly not have been fitted correctly.
Sunroof drains gets blocked and overflow into the cabin if you have one.
Mike
South Coast
