Author Topic: Mk5 Golf GTI Rear Shock Replacement – Best OEM Feel Without Dealer Prices?  (Read 2736 times)
Offline Husy
Hi all, looking for some advice on rear shocks for my MK5 GTI 2008 (BWA). I need to replace both rear shocks and want to keep the OEM ride feel and quality without paying dealership prices. Any recommendations on brands/models that are closest to factory spec? Cheers.
Offline GVK
  • -Receive: 76
    • GVKmotorsport
Look on sites such as Autodoc for Sachs dampers (oe supplier)
Offline Jons1001
  • -Given: 22
As above. I bought these from Autodoc a few months back and no issues. Part number 310950.
Offline Husy
Hi both, thanks for the advice on the Sachs rear shocks and for sharing the Autodoc part number, really helpful. Did either of you also use the Febi dust cover and bump stop kit (176504) along with the Febi strut top mounts (23024)? If so, how was the quality and fitment, or would you recommend sticking with Sachs for those parts as well?
Offline ZoliWorks
Sachs used to be the old supplier for VW back in the mk5 era but now they are using Monroe. I have not had any experience with Sachs myself but I've recently fitted Monroe all around my old car. I've had KYB previously and the shocks might as have been welded stiff. If you want comfort, stay away from those. My other car on Bilstein b4 sport, Eibach pro-kit and 18" wheels was more comfortable than the KYB shocks on stock coils and 16" wheels. Monroe on the other hand, I instantly felt the difference, especially going over speed bumps.
If you want comfort, go with either Sachs or Monroe.
As for the dust covers and upper mounts, for the rear doesn't really matter what you pick, just check whether your mounts are oval or round. Not sure what the exact difference is between the 2. Maybe just something VW changed over the years? They are interchangeable but I'd assume the oval ones provide much more bottom out damping force as they are wider.
Mk5 Jetta 2.0 TFSI BWA | Manual | Mk6 GTI Front | BorgWarner K04 Turbo | Sachs X-Tend Clutch Kit | Ta-Technix Air Intake | Ta-Technix Cat-less Downpipe | Ta-Technix Sandwich Intercooler | OEM S3 Injectors | Vis Motorsport 175 bar HPFP | 319hp 491nm
