Author Topic: Squeal after cat change  (Read 5619 times)
Offline blake
« on: June 19, 2026, 03:27:43 pm »
Hey,
I’ve had the cat changed due to old one rattling. Picked up car today and don’t know if it’s placebo but seems to boost abit better, however it almost seems like it squeals abit now which increases under acceleration.
Anyone any ideas? I don’t like taking the car back if alls okay but on the same point I don’t want to get to an MOT in 9 months and find out I’ve got exhaust blowing or something.
Offline ZoliWorks
Re: Squeal after cat change
« Reply #1 on: July 02, 2026, 12:37:28 am »
Drive it for a few weeks and then have it checked. If it has exhaust blowby, you'll have clear carbon deposits around the leak.
Mk5 Jetta 2.0 TFSI BWA | Manual | Mk6 GTI Front | BorgWarner K04 Turbo | Sachs X-Tend Clutch Kit | Ta-Technix Air Intake | Milltek Catless Resonated Exhaust | Ta-Technix Sandwich Intercooler | OEM S3 Injectors | Vis Motorsport 175 bar HPFP | 319hp 491nm
Offline blake
« Reply #2 on: July 03, 2026, 05:49:10 pm »
I had it smoke tested today as the garages its been to think its just uncovered another problem. Culprit is the hose from pcv in the photo, anyone know part number of it? Also its simple enough to detach from the top but has anyone got any experience removing the other end, i cannot get my hands in there.
It’s the taped up one.
Offline blake
« Reply #3 on: August 14, 2026, 10:34:25 am »
Just thought id put an update here in case anyone has similar problem in future. I changed the hose from pcv, had it run again on smoke test, nothing found. Car boosts fine so the garage I used suspected it being the way the cat sounds as its aftermarket.
