Author Topic: itg filter noise?  (Read 6449 times)
Offline hopey
itg filter noise?
« on: April 22, 2010, 09:22:06 pm »
hi i mite be just over reacting but i fit my itg filter today and forge dumpvalve. And there is a noise comeing though the filter at about 3500 rpm the sound is like a sqeek quite loud. And just wunderd if this noise comes when you fit itg filter. i think it could be the waste gate but im not shure thanks.
Re: itg filter noise?
« Reply #1 on: April 22, 2010, 09:28:08 pm »
Sounds normal mate, my ITG is very noisy.  Its a trait of open filters, enjoy it!
« Reply #2 on: April 22, 2010, 10:40:06 pm »
Can't say I get a 'squeek' as such but I get plenty of other noises!  :evilgrin:
« Reply #3 on: April 22, 2010, 10:41:22 pm »
More of a 'sneeze'!
« Reply #4 on: April 22, 2010, 10:49:10 pm »
« Reply #5 on: April 22, 2010, 10:50:48 pm »
If it's a consistent 'squeak', there's been some posts in the American forums about solving it when aftermarket high-flow tubular intakes are fitted.
Is your car an Ed30 or a GTI, or something else?
« Reply #6 on: April 23, 2010, 01:16:33 am »
slightly of topic but are the itg panel  filters the best to get and worth the extra money or pipe filters as good
« Reply #7 on: April 23, 2010, 08:37:12 am »
....I've had both but not scientifically tested them. Not really any noticeable difference in performance but the ITG panel filter absolutely fills the airbox space much better and its material would do a better filtration job longer term.
My ITG panel filter is for sale but has done about 50k miles and needs reconditioning (not difficult but messy).
« Reply #8 on: April 23, 2010, 12:38:21 pm »
mine is a gttdi R/R so its probs different
Offline hopey
« Reply #9 on: April 23, 2010, 01:16:42 pm »
ive got a gti its very noitceable does it when boosting sounds like a split hose but checked and all looks fine
« Reply #10 on: April 23, 2010, 02:23:42 pm »
I've just been having a long chat with Forge giving them Twintake feedback amongst other things, and we discussed how every aftermarket intake will sound different on each car. That applies to exactly the same high-flow tubular intake on different cars. It's simply because of the harmonic reverberations which each individual car setup will have and the consequent sound transfers.
You can also vary the sound with your right foot (throttle).
Add to that the fact that we each hear different sound frequencies slightly differently and also have differing preferences in what we like to hear. = One man's meat is another one's poison.
Hurdy's EVOMS sounds like a laughing Hyena.
« Reply #11 on: April 23, 2010, 02:56:45 pm »
laughing Hyena sounds about correct  :grin: i have the same intake too  :laugh: its bloody loud
« Reply #12 on: April 23, 2010, 05:45:40 pm »
With regards to 'squeeking'.  When I initially fitted my ITG there was squeeking, it was the silicone hoses as I didnt use silicone lubricant spray when fitting.
Offline hopey
« Reply #13 on: April 25, 2010, 09:14:31 pm »
hi i have found where my sqeek was comeing from i removed my dumpvalve and found the orange seal split so im going to order an up rated one from awsome gti would thtis of split due to my forge dumvale spacer and will it cause any more trouble thanks for everyones help
« Reply #14 on: April 25, 2010, 09:19:11 pm »
hi i have found where my sqeek was comeing from i removed my dumpvalve and found the orange seal split so im going to order an up rated one from awsome gti would thtis of split due to my forge dumvale spacer and will it cause any more trouble thanks for everyones help hi i have found where my sqeek was comeing from i removed my dumpvalve and found the orange seal split so im going to order an up rated one from awsome gti would thtis of split due to my forge dumvale spacer and will it cause any more trouble thanks for everyones help
.....Phew! I'm now out of breath and my head is spinning.  :grin:
But, anyway, we're glad to hear your problem is solved  :happy2:
A Warm Welcome to the forum, by the way.
