Author Topic: Brake Fluid Change. How often?  (Read 8354 times)
Offline nc35
  • -Given: 40
« on: June 02, 2010, 05:57:33 pm »
Hi All
I know the service manual and the stickers say every two years, but service delta don't seem bothered.
Just booked wifes car in for first service @ two years with only 7k on the clock. Service guy didn't think fluid change was needed.
I have got him to add it to the service for £25 which I didn't think was bad.
Thought DOT4 fluid absorbes water.
Can anyone shed light on this?
Lee
No Golf anymore.
Enjoyed the last five years of ownership of Mk5 & 6 GTIs.
Plus an excellent forum for knowledge and new ways to deplete the bank account.
Thank You Everyone.
Offline Janner_Sy
  • -Receive: 113
Re: Brake Fluid Change. How often?
« Reply #1 on: June 02, 2010, 06:00:53 pm »
25 quid is an absolute bargain for brake fluid change.
Offline DaveB@Vagbremtechnic
  • Trader - 2014
  • -Receive: 130
    • Vagbremtechnic.com
« Reply #2 on: June 02, 2010, 06:06:32 pm »
Dont worry about dot 4 or 5 its just a specification, an OEM quality Dot 4 will be much better than a Halfords Dot 5.
If the OEM stuff is indeed dot4 then it might be something freaky such as the freezing viscosity level that might not meet the Dot5 specs it will be better than your average Dot 5 you just cant use it in Alaska in winter!
Its also worth a mention that the Mk5 OEM stuff is also used on a ceramic braked V10 R8 - it comes into "if it aint broke" category imvho of course if you're boiling it off on track days then RBF the way even then just bleeding out the stuff that got hot would go a long way.
The £25 fixed cost thing is a bloody bargain, get a load of guys complaining of a soft pedal after spending hundreds on a BBK and then installing it on the driveway......The Dealer OEM bleed is a good option to sort it, the SEAT dealers also know what they're doing with four pots
Offline Janner_Sy
  • -Receive: 113
« Reply #3 on: June 02, 2010, 06:57:11 pm »
must admit i boiledmine at the ring, although the fluid had been in the car since new at that point. (2 years)  at the end of the ring i could pretty muich do 3/4 of the brake pedal with no effect :surprised:
Offline nc35
  • -Given: 40
« Reply #4 on: June 02, 2010, 06:59:42 pm »
Thanks for your replies.
As per your answer is top notch Dave glad you saw the post.
Is it true that the fluid absorbs water over time hence needing the change?
No Golf anymore.
Thank You Everyone.
Offline Janner_Sy
  • -Receive: 113
« Reply #5 on: June 02, 2010, 07:04:26 pm »
thats the reason for the two year change
  • Trader - 2014
  • -Receive: 130
« Reply #6 on: June 02, 2010, 08:02:54 pm »
Yep its Hygroscopic, nearly all mineral oils do over time. We change our Hydraulic fluid in our airplane every 1000 hours so roughly two years, theres mil spec stuff which isn't used much anymore called Skydrol that resists water absorption  but its frickin nasty stuff you'll probably still have it in chinooks and the loadies'l be telling you to avoid stepping in it as it'll melt your boots!  :scared:
PS Dont put "aquired" skydrol in you're Octy  :laugh:  :laugh:  :grin:
Offline Janner_Sy
  • -Receive: 113
« Reply #7 on: June 02, 2010, 08:15:10 pm »
it wouldnt be stolen or aquired. we refer to it as redistribution of essential eqiuipment.
Offline Merlinman
« Reply #8 on: June 02, 2010, 08:15:40 pm »
First brake fluid change is now at 3 years not two - get your dealer to confirm.
  • Trader - 2014
  • -Receive: 130
« Reply #9 on: June 02, 2010, 08:16:21 pm »
 :signLOL: :signLOL:
Offline Tarmac_Terrorist
« Reply #10 on: June 02, 2010, 11:06:09 pm »
I don't undertand why the initial brake fluid change is now recommended at 3 years instead of 2, but then every two years thereafter??
I assume it's the same spec fluid that dealers use as it is at the factory.
Offline gillm
« Reply #11 on: June 02, 2010, 11:09:35 pm »
i do mine every year or before a track day . and i use comma 5.1
west tuned gt28 @ 340hp
Offline FamilyDub
  • ...who needs a diesel?
« Reply #12 on: June 03, 2010, 10:53:09 am »
^^^ +1. Excellent price.
I paid £35 from an independent VAG specialist for the fluid for OEM stuff, as a comparison?
MKV GTI | Reflex Silver | 5-dr, Family-Spec | 17" w/anthracite Finish | Manual | Highline | Cruise | Revision 'D' DV | Dirty Pipes |
« Reply #13 on: June 03, 2010, 10:55:26 am »
£30 quid for fitting my goodridge hoses & changing my brake fluid was a bargain for me  :smiley: :happy2:
