Author Topic: CAN BUS GATEWAY  (Read 4573 times)
Offline rotty80
CAN BUS GATEWAY
« on: June 25, 2010, 08:17:22 am »
Hi,
can anyone help will this can bus gateway 1K0 907 530 AD be ok in my 2006 gti.   :smiley:
Offline mclovin
Re: CAN BUS GATEWAY
« Reply #1 on: June 25, 2010, 11:20:54 am »
Yes, I fitted the same one to my 2006 GTI. You will need to completely recode it using VCDS and as this new CAN BUS uses a much longer HEX string than your original one (it has more options available). This means you can't just copy over your current coding, you'll have to go through each option one by one. Sounds daunting but it isn't that bad, I did mine myself.
Offline rotty80
Re: CAN BUS GATEWAY
« Reply #2 on: June 25, 2010, 02:18:29 pm »
Thanks for your advice, do you know how much it would cost me at the dealers to have it coded? :smiley:
Offline Poppa Dom
Re: CAN BUS GATEWAY
« Reply #3 on: June 25, 2010, 02:38:30 pm »
No sure mate - but I would want it to be coded correctly too  :signLOL:
Offline mclovin
Re: CAN BUS GATEWAY
« Reply #4 on: June 25, 2010, 03:34:55 pm »
It really isn't that difficult to do if you have a good working knowledge of VCDS and have a print out of the original settings. I didn't find it to be much of a problem at all, but I am an IT Consultant so I've never found VCDS coding to be particularly taxing.
Offline rotty80
Re: CAN BUS GATEWAY
« Reply #5 on: June 25, 2010, 03:55:07 pm »
Do you Live anywhere around  Mansfield area  :grin:
Offline mclovin
Re: CAN BUS GATEWAY
« Reply #6 on: June 25, 2010, 04:20:27 pm »
Sorry mate, I'm in Reading!
There must be someone near you who has VCDS skills and can help you out...
Offline mortygttdi
  • -Receive: 146
Re: CAN BUS GATEWAY
« Reply #7 on: June 25, 2010, 07:22:08 pm »
I'm in Leeds if thats any good.
Darren
Offline rotty80
Re: CAN BUS GATEWAY
« Reply #8 on: June 25, 2010, 07:38:00 pm »
Thanks.  :happy2:  but i get lost very easy .
Offline rotty80
Re: CAN BUS GATEWAY
« Reply #9 on: July 08, 2010, 03:25:48 pm »
Can someone who lives in the mansfield area pleaseeeeee help me code my new can bus gateway. :smiley:
Offline MattPoss
Re: CAN BUS GATEWAY
« Reply #10 on: July 08, 2010, 05:11:43 pm »
Take the trip and go and see Darren (mortygttdi)
He's a genious at the diagnostics and electrical side of things, he supplied, fitted and coded my new Canbus Gateway for me.
I go and see him and I live in Carlisle which is over 2hrs away, Mansfield isn't that far really!
Matt
