Author Topic: rich83 - Edition 30..... Breaking  (Read 859064 times)
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=4epptljlnh7qluinp7q18atini&/topic,19740.0.html
Re: rich83 - Edition 30
« Reply #2205 on: July 26, 2015, 09:29:08 am »
Yeah I've heard they are preferable to kw from a few people. I've not read one bad review on the Internet.
Friday sees a new steering rack being put on and these fitted. Setup the same ride height as current and all re-aligned.
Offline xjay1337
  • -Receive: 377
« Reply #2206 on: July 27, 2015, 09:59:54 am »
Brilliant rich, althought admit you want to go another 10mm lower :P
About time there was a worthwhile update in your build thread.
« Reply #2207 on: July 27, 2015, 10:02:14 am »
I don't use the adjuster rings on the back with my pss10. They aren't the lowest coil overs, my kW where slightly lower but I like to think the Billy's are more about performance
« Reply #2208 on: July 27, 2015, 10:10:48 am »
I am guessing that you are probably about 10-15mm lower on the rear (possibly all-round).
Plan is to measure the current ride height and match it exactly with the PSS10, as I like the ride height and hardly ever have clearance issues.
« Reply #2209 on: July 27, 2015, 10:11:11 am »
Ohh jay.... you are a one...  :booty:
« Reply #2210 on: July 28, 2015, 10:14:18 am »
Just clicks over 90,000 miles last night. So that's 77,000 in my ownership.
Should be running sweet as a nut by the end of summer set for another 90k  :smiley:
« Reply #2211 on: August 02, 2015, 12:43:32 pm »
So friday saw a new steering rack go on. The groaning has gone so thats a relief.
New
PSS10s went on. Seemed to go on easily enough.
And then onto TT Shops old to do the alignment, where a problem was struck.
Alex has been telling me for probably about 2 years that the rear TOE adjustment bushes are seizing up, the ones on the left here...
ignore the text on the image, its wrong
Anyway... the bolt snapped so I am having superpro bushes put in with new bolts, should hopefully make all future alignment much easier
I only drove the car about 5 miles but the first impressions of the PSS10 is good. No where near as hard as I thought they would be (set to F5 R4). Damping is much much improved over the trashed OEM dampers, which all appeared to have very little in terms on compression damping.
More on the PSS10 once I've got it back
« Last Edit: August 02, 2015, 01:29:19 pm by rich83 »
Offline jaffa
  • -Receive: 44
« Reply #2212 on: August 02, 2015, 01:20:59 pm »
isn't that eccentric bolt for toe? the camber eccentric bolt is higher up towards the front of the car
« Reply #2213 on: August 02, 2015, 01:26:00 pm »
Yes... you are correct, got it mixed up, as did the person who made that image (not mine)  :signLOL:
Offline jaffa
  • -Receive: 44
« Reply #2214 on: August 02, 2015, 01:28:32 pm »
I'm sure iv seen that picture a couple of times on the forum  :signLOL:
so which ones are getting replaced camber or toe?
« Reply #2215 on: August 02, 2015, 01:29:45 pm »
The toe ones  :happy2:
Offline Dave J
  • -Given: 45
  • -Receive: 63
« Reply #2216 on: August 02, 2015, 04:54:34 pm »
Great to read - can't wait to get rid of my OEM dampers now. They are exactly as you describe... no compression...
What alerted you to the steering rack giving up?
Edition 30 - no. 1387
« Reply #2217 on: August 02, 2015, 05:11:46 pm »
It was making noise when steering. It wasnt 'that' bad, but it was only gonna get worse and annoyed me and made the car feel old.  :sad1:
« Reply #2218 on: August 02, 2015, 06:23:58 pm »
Has it lowered the ride height a bit
« Reply #2219 on: August 02, 2015, 06:31:51 pm »
It was actually a little bit higher (not fussed about 'lows' too much).... but Im hoping that alex drops it to 36cm all-round same as before.  :happy2:
