Author Topic: vRSAlex's Octavia vRS Estate - New Mods On  (Read 350612 times)
Offline Daemon
Re: BDMAlex's Octavia vRS Estate
« Reply #180 on: November 18, 2011, 12:26:13 pm »
Hello Alex,
My name is also Alex and I also own an Octy vrs  :signLOL: . I want to do the same mod as you with a big bov and i need to know how much in/Hg  is the engine vacuum so I can choose a spring for a Tial q BOV.Thank's a lot, great car by the way.
Offline cupra_k1
« Reply #181 on: November 18, 2011, 07:21:11 pm »
Hello Alex,
My car idles at around 20-22in/hg if thats any help mate.
Cars looking awesome btw Alex (BDM)  :happy2:
Offline Daemon
« Reply #182 on: November 20, 2011, 09:46:08 pm »
Hello Alex,
That helped a lot, thank's man.
Offline vRSAlex
  • -Receive: 253
« Reply #183 on: December 01, 2011, 10:07:13 pm »
It's about time for some new front brakes:
These will go on after winter as my winter wheels are too small.  They will go straight onto the 345mm disc with a new bracket.
Follow AKS tuning on Facebook
« Reply #184 on: December 01, 2011, 10:09:41 pm »
They just made my little Gentleman twitch.  :happy2:
Offline damoegan
« Reply #185 on: December 01, 2011, 10:10:57 pm »
Nice  :happy2:
Who makes them?
« Reply #186 on: December 01, 2011, 10:11:24 pm »
At a guess I would say Audi.  :laugh:
Offline vRSAlex
  • -Receive: 253
« Reply #187 on: December 01, 2011, 10:16:00 pm »
Nice  :happy2:
Who makes them?
Made for Audi by brembo. They are virtually the same caliper as the DB9/F40/Gallardo rears.
Dave makes the brackets and lines to get them on.
Offline vRSAlex
  • -Receive: 253
« Reply #188 on: December 01, 2011, 10:18:47 pm »
:signLOL:
I've got a pair of R8 8 pot fronts too.  Just a little bit overkill for a Skoda.
Offline damoegan
« Reply #189 on: December 01, 2011, 10:20:17 pm »
 Had a feeling they would be Brembo's *cough, Mr Hedge*  :laugh:
« Reply #190 on: December 01, 2011, 10:46:10 pm »
Sounds like you will be moving a large quantity of fluid to get them working.
Will you be fitting the uprated master cylinder?
I take it the 345mm disc is from the R32? What wheels can you fit with them?
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=ph1vo1vlhjdohprqv2el1f9gu8&/topic,19740.0.html
« Reply #191 on: December 01, 2011, 11:02:42 pm »
The should fit under most 18s from what I remember, may need a small spacer.
Offline vRSAlex
  • -Receive: 253
« Reply #192 on: December 02, 2011, 12:43:53 pm »
The R8 calipers has a slightly smaller piston size which im assured by 'The Guru' will work fine with the standard master cylinder.  If I dont like the feel then I will upgrade.  Doing a cylinder change isnt a quick job though.
Ive not tried them on my wheels yet, but it will be 18's or larger to get them on.  They dont fit with my winter wheels which is a bummer.
The DaveB brackets allow the caliper to fit with the standard 345mm discs  :happy2:
« Reply #193 on: December 02, 2011, 01:33:30 pm »
That sounds an excellent solution but definitely overkill on my car.  :wink:
Offline s3dubbin
« Reply #194 on: December 02, 2011, 05:17:07 pm »
Nice mod! Need to watch out for a set if its that easy! Right colour aswell.  :happy2: Stevie.
