Author Topic: vRSAlex's Octavia vRS Estate - New Mods On  (Read 308902 times)
Offline vRSAlex
  • -Receive: 253
Re: vRSAlex's Octavia vRS Estate - R8 Calipers now on
« Reply #495 on: March 27, 2013, 08:56:31 pm »
what did you do with the ceramic coated pieces off your ITG intake  :evilgrin:
Need to sell the kit when I get a chance.
Follow AKS tuning on Facebook
« Reply #496 on: March 27, 2013, 08:58:08 pm »
Paint man, Paint man, Paint man, Paint man
Offline vRSAlex
  • -Receive: 253
« Reply #497 on: March 27, 2013, 09:04:48 pm »
those CKs clear the big brakes OK Alex? do you have anything done with the shifter? I hear you do the shifter bushings, thinking of them for my VRS
They will just clear without spacers but I would advise using a 3mm or a 5mm.  Wheel weights do cause an issue but with some clever positioning and balancing they are good.
I do a shifter bracket solid bush kit.  Back in stock in a week or two.
Offline vRSAlex
  • -Receive: 253
« Reply #498 on: March 27, 2013, 09:05:27 pm »
You need to bombard me when im at work!
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
« Reply #499 on: March 28, 2013, 11:27:51 pm »
Saw the CK's in person tonight. They looked stunning  :drool: Perfectly filled the arches in 18"s and I'd pick them over 19"s for running costs, look no smaller to me  :happy2:
Lovely motor and Alex is a top guy. More or less confirmed my purchase order for CK's 18x8J too...
Pete
Offline danishmkvgti
  • -Given: 243
  • -Receive: 155
« Reply #500 on: March 29, 2013, 08:31:28 am »
Intake kit change.  Was running the ITG that I copied but ceramic coated.
Before:
New Revo kit:
Fitted:
Overall its improved low down and mid range power.  Holds boost for longer.  Peak maf before and after is identical to the old kit at 275 g/s but peaks higher throughout the rest of the rev range.
Looks and fits great too and to show a gain against the other best kit on the market is good news to me.
Before my RR yesterday we did a 4 gear pull and the LOBA showed 300g/s on the MAF  with the REVO intake fitted :happy2:
« Last Edit: March 29, 2013, 08:35:33 am by danishmkvgti »
Over the top mod list ;o)
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=8rqkebiifkk8daenedd0k8j279&/topic,19740.0.html
« Reply #501 on: March 29, 2013, 01:55:27 pm »
 :drool: :drool: :drool: :drool: :drool: :drool: :drool: :drool: :drool:
 :wink:
Offline daz_pd
  • My VRS
« Reply #502 on: March 31, 2013, 03:02:34 pm »
Alex if you could, could you PM me the price for the Shifter kit, what does it consist of/what are my options/what do you recommend? have you fitted any to a FL VRS yet as I think I will need the MK6 GTI kit (can take pics for you anyway if need be) cheers!
« Reply #503 on: April 30, 2013, 09:57:07 am »
Have to say the CKs look beyond stunning. That anthracite matches the blue perfectly.
Looks immense in the sunlight / in the flesh!
Offline 4dyctdi
« Reply #504 on: April 30, 2013, 06:07:49 pm »
Stunning car
Offline vRSAlex
  • -Receive: 253
« Reply #505 on: June 18, 2013, 12:31:05 pm »
I've been a bit slack on the updates recently.  Not really had any time, but got a few bits done.
Original TB died and luckily I had a larger one sitting on the shelf ready to go on.  Fitted on perfectly and also added a WMI spacer plate.  The up pipe was also screaming to be replaced, so fab'd up a new larger bore version in alloy.
Performace wise the car picks up boost better and there is more throttle response too.  Not sure if its really make a massive overall power gain.
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
Re: vRSAlex's Octavia vRS Estate - New Mods On
« Reply #506 on: June 18, 2013, 12:35:18 pm »
Nice work there Pal  :happy2:  Did you put any taps for wmi on the throttlebody pipe like the bsh pipes?
Or just the wmi spacer?
Silver is the way !
Offline 2fast4you
  • Some drive to work... I work to drive!
« Reply #507 on: June 18, 2013, 02:34:09 pm »
What is that TB from ??? And what size? Any problem wit the map ?  :smiley:
Offline flatout
« Reply #508 on: June 18, 2013, 07:45:56 pm »
loving the up pipe,maybe there could be a group buy on soon for those?????????? :happy2:
stage 2+ Grey Ed30..DSG 362 BHP.380 lb/ft.....Also Statller Tuned :)
Offline GarethB
« Reply #509 on: June 18, 2013, 09:55:28 pm »
+1 Sort it Alex.
I'd be happy to sample one on Tuesday when my car is in  :happy2:
