Author Topic: Suspension and Drivetrain Advice Required Please  (Read 7930 times)
Re: Suspension and Drivetrain Advice Required Please
« Reply #15 on: February 06, 2011, 03:38:13 pm »
Has anyone mentioned brakes and engine mounts in this thread yet? - All part of the suspension and drivetrain.  :evilgrin:
I advise doing mods bit by bit so you understand better the effect of each and also in the perhaps unlikely event you raise a problem it's easier to diagnose and correct. It is also kinder on your wallet - Wifey: "What the heck has happened to all that money we saved for the new kitchen!?". The word "we" means something different in the female dictionary.
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #16 on: February 06, 2011, 03:46:58 pm »
Agree.
Another point is that I might like a setup and someone else might like a different setup.
The reason for different camber is from front to back is, in my opinion, the manufacturer's desire to make the car stable and rather understeer than oversteer. Because I fell the need for more camber doesn't mean that all of us should. I checked my tires and fount that the outer part was worn more than the interior. This means I need more negative camber.  Everybody can easy check if they need more or less camber if they check the temperature of the tires (the outer part, the inner part and the middle). If the outer part temperature is higher than the inner temperature than more negative camber is required. If the middle part has a higher temperature than the outside's than the tires are overinflated.
« Reply #17 on: February 06, 2011, 03:47:59 pm »
....Yes, but there are reasons why the Mk5 GTI has more camber on the back than the front.
Please enlighten us Obi-Wan.  :popcornsoda:
....I didn't say that I actually knew the reasons  :laugh:
I have been told many moons ago and have forgotten the detail but think it's something to do with the Mk5's rear suspension arms etc. I'm having my car aligned and tracked on a Hunter rig next Wednesday and will ask and let folks know.
Btw, @ Matt the OP: Always get your car aligned etc after a suspension mod. Hunter laser rigs are reputed to be the very best.
Offline bart
« Reply #18 on: February 06, 2011, 03:51:44 pm »
cheers mate
where are you going to get you car aligned and tracked at
Tornado red ed 30,dsg,rcd 510,milltek de cat tbe,walk kit,kw v3,revo stage 2+,dsg stage 2+,hpfp,itg cai
« Reply #19 on: February 06, 2011, 03:57:51 pm »
cheers mate
....Denmead: Not far up the A3 from JKM Portsmouth and highly recommended by JKM. They align all sorts including Ferrari's and full-on race cars. They're a small family business (like JKM) and talking on the phone to them it's clear they take a great pride in and enjoy what they do.
« Reply #20 on: February 06, 2011, 04:05:48 pm »
Agree.
....Absolutely, we each have our own preferences. Mine is for feeling taut and tactile even at the expense of a little comfort: Hard but not harsh. It makes me feel more confident and less caccooned.
Isn't a gadget for measuring the temperatures across different sections of a tyre fairly specialised? The nearest I get to that is a TyreSure monitor with sensors in each wheel which relays pressure and temp for each individual tyre to a small display. It of course only provides one temperature value but does so every 5 seconds. It won't help with assessing any need for more/less camber.
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #21 on: February 06, 2011, 04:09:05 pm »
The device is called "Pirometer" (I hope this is the English name) and from what I understand is a very very useful device for camber setup and tire pressure setup.
« Reply #22 on: February 06, 2011, 04:13:58 pm »
....Correctly spelt pyrometer (but don't worry, your spelling is better than many English people!).
Wikipedia:   http://en.wikipedia.org/wiki/Pyrometer
Offline RagingKileak
« Reply #23 on: February 07, 2011, 07:32:10 am »
I think this thread has become rather more helpful overnight, shame I missed it.
I personally doubt I will do the TT arms as part of any 'Stage 1' suspension mod. It seems like a big parts price before labour, with perhaps less apparent result than ARB's or an uprated Springs/Shocks set.
I'm keen to know more about the bang per buck opinions on one set of ARB's vs another. In BMW land, thicker is not always better and I'm guessing some adjust and others don't etc. What's fitting like on the front and rear with the MK5?
Also coilies vs a good fixed kit. Thats a tough one... I don't see any evidence that 'enough' R&D has gone into any fixed set, eg the B12 kit. Plus of course there is my weight etc which needs to be accounted for.... Coilovers are typically overkill for me though. I know for an absolute fact that I'll never change the setup following the initial purchase.
Brakes wise I have R32 brakes which seem fine, albeit heavy. I'd have bought the car from John modded yes, though not with NOS and probably not with the tenpot brakes.... both are a step too far. Oh, Engine Mounts I've definitely considered too, but not in this 'phase' really.
My nearest hunter machine is in wakefield. I went there to setup my M3 for the track and will do so for the MK5 too.
Cheers so far.
Matt
« Reply #24 on: February 07, 2011, 08:01:35 am »
It builds understeer Robin which to Joe Public is a far safer and more progressive way of telling them they have overcooked it.  :P
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #25 on: February 07, 2011, 06:00:16 pm »
Matt,
it's your own decision to choose the right parts. Nobody else will know what's best for
you. Driving, steering, ride comfort - all a question of personal taste.
Coilover B14 or just B12? I don't know what's right for you but I'd go für the B14 then.
ARBs? I've chosen the 28/24 mm H&R, but if TÜV wouldn't be a problem I would have
done it like Rex did (26 + 24 mm) or I'd gone for the APR or Hotchkis (27/27 mm hollow).
H&R advantages:
- excellent Quality
- very stiff (28/24 mm almost 3 x stiffer than stock)
- Teflon lining bushings
- TÜV
Before I got the H&R I thought a stiffer ARB in the rear is more important.
So first I adjusted them soft front and stiff rear.
But this wasn't the best for my car and my taste. The stiff setup front & rear
improved turn in without disturbing traction too much.
But this is choise and my taste.  :wink:
It depends from the suspension as well. There will be a difference between
stock and a KW Clubsport.
As well important:
Whiteline ALK, TT arms and hubs, performance tyres like PSS or even semi slicks.
"You get what you pay for."
Offline Janner_Sy
  • -Receive: 113
« Reply #26 on: February 07, 2011, 06:16:53 pm »
... I'm not sure about the TT arms: I don't see how you can avoid some uneven tyre wear if you add camber ...
RedRobin, VW advices camber up to -2.15' on the back. If they say this is normal, I don't think we should be concerned going to that value (even in the front). Also under cornering the camber changes and we get more positive results.
I'm getting my car aligned and tracked on a Hunter rig next Wednesday so I'll report what I'm advised about cambers.
what he is saying RR is that if the cars can run -2.15' on the rear without accelerated tyre wear or uneven tyre wear then it will be fine to use that amount of camber and more on the fronts.
and Ian has already mentioned why the cars run more rear camber normally
« Reply #27 on: February 07, 2011, 07:02:29 pm »
.... :drinking: Cheers, Sy.
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #28 on: February 07, 2011, 08:29:14 pm »
Thank you for translating  :happy2:. I might need a translator after all  :innocent:.
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #29 on: February 07, 2011, 08:39:11 pm »
but if TÜV wouldn't be a problem I would have done it like Rex did (26 + 24 mm)
As I understand I have TUV for both bars instead of one for the whole kit.
I just didn't like the available kits and wanted something in between. And so I ordered the bars separately (this was more expensive, of course).
