Author Topic: Pipwerx downpipe bottleneck??  (Read 2328 times)
Offline craig_t
  • Craig
« on: February 17, 2011, 09:45:57 am »
I know fitting and a diwnpipe to stock cat back has been covered, but if I fit my 3" downpipe to stock cat back will having a reducer bottle neck the extra gases flowing threw the downpipe.
I know a few people have the same sort of set up and have felt good results, it's just after emailing a few garages on fitting this, they have mentioned it would not be a good idea without a 3" all the way through.
Admin notice, sig pic removed for being to big.
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: Pipwerx downpipe bottleneck??
« Reply #1 on: February 17, 2011, 09:51:03 am »
I say do it.
One of your biggest bottle necks is in the Cat.  The aftermarket Cats are generally 200 CEL race/performance Cats.
Stu...
Offline craig_t
  • Craig
« Reply #2 on: February 17, 2011, 02:25:44 pm »
Yeah it has a 200 cell.
I keep reading that a 3" down pipe is better on ko4 rather than the smaller ko3 that I have.
Offline muckipup
  • -Receive: 25
« Reply #3 on: February 17, 2011, 04:15:58 pm »
I can assure you that a 2.5" cat-back will have next to zero detrimental effect over a 3" cat-back when a 3" dp is used
PS and fyi - my car threw a rear lambda CEL with the Pipewerx dp and Stage 2. It was a false cat inefficiency CEL caused by the rear O2 sensor picking up the different flow characteristics (passed MOT emissions test by a long way!). Others have been luckier and I haven't heard about it with Milltek 2.75" dps. I have since changed to Revo software and they map this inconsequential CEL out as standard from Stage 2 on.
« Last Edit: February 17, 2011, 04:22:56 pm by muckipup »
Offline Janner_Sy
  • -Receive: 113
« Reply #4 on: February 17, 2011, 05:27:37 pm »
do it, i had ther pipewerx DP and its very good.  As for saying you need a 3" DP,
Dan GB has a 2.75" on his GT28 big turbo TFSI running 400Hp+
Offline craig_t
  • Craig
« Reply #5 on: February 19, 2011, 10:11:16 am »
Thanks for the info guys  :happy2:
