Author Topic: Good or bad?  (Read 3286 times)
Good or bad?
« on: February 25, 2009, 07:02:51 pm »
So I'm driving down this single track carriageway at a lovely steady 40mph using cruise control (courtesy of vrStu  :happy2:), mainly because no one else seems to realise that a white circle with a black line going through it diagonally means NSL and hence continue at 40 instead of 60.
Anyway, after swinging round a roundabout and heading for the DC, I was on a slip road pulling 30mph in fourth. There's a fair bit of traffic on the slip road so I go slow. I join the DC and decide I should be in the outside lane, so I drop from fourth down to second and the revs shoot from 2000 to 6000+, overtake and quickly slip through the gears until I'm at 70mph in 6th. God I love that surge of acceleration.
The question: Is shooting the revs up like that likely to mess things up in regards to the engine/turbo?
Re: Good or bad?
« Reply #1 on: February 25, 2009, 07:17:23 pm »
Nope you will do it more harm flooring it in a higher gear i believe this will stress the clutch.
Engines are designed to rev  :driver:
Any way 30 in second gear must be miles away from the rev limit that would not even be 4000rpm  :chicken:
Re: Good or bad?
« Reply #2 on: February 25, 2009, 07:21:50 pm »
30 was on the slipway. I was on the DC when this happened and was travelling fairly fast - dunno what it was but I was in 4th at 2000 revs on the DC and then changed down to 2nd.
Re: Good or bad?
« Reply #3 on: February 25, 2009, 07:25:52 pm »
TWill be fine dude you also have a rev limiter, which some one will correct me if i am wrong but it would have just bounced off that until the revs where low enough.  :smiley:
Offline TomB
Re: Good or bad?
« Reply #4 on: February 25, 2009, 07:26:41 pm »
Rev limiters are there for a reason so you'll be fine.  That said, dropping it into a low gear at high speed will do a fair amount of damage, so never be sloppy when changing down!  I know this brings up the fault code "Rev limits exceeded: Warranty void  :)" and we don't want that!
Tom
05 GTI - 18" Merc wheels, coilovers, colour coded Votex kit, all waiting to go on.
Re: Good or bad?
« Reply #5 on: February 25, 2009, 07:31:58 pm »
That's what I thought. Needed the turbo spinning and didn't think it'd spin fast enough if I went down to third so went down to second.
Offline TomB
Re: Good or bad?
« Reply #6 on: February 25, 2009, 07:37:11 pm »
Valvers love being dropped down a cog or two and being driven to the redline, the power is at the higher end of the rev range.  Its one of the reasons I'm back in a GTI after a few years with a TDI.  I dropped 2 cogs in that and almost blew it up!
Tom
Offline Toptrump
Re: Good or bad?
« Reply #7 on: February 26, 2009, 08:48:44 am »
You just need to drop down so the turbo is still "on" boost, and because they are pretty small things they spin up at low RPM so I would think 3rd would have been fine.
With regards the rev limiter, I didn't think the rev limited actually worked when you changed down to far.  I have seen the little needle way past what the limited was on my Civic by hitting the wrong gear by mistake.  Not tried it in the Golf to see.  :smiley:
Walk softly and carry a big gun!
