Author Topic: Fuel Cut on Stage 1???  (Read 13019 times)
Offline johnhol78
« on: April 11, 2011, 02:08:05 pm »
Had my custom map done last week and did my service yesterday (pipercross airfilter, spark plugs, pollen filter and oil service)
Now at lunchtime I floored it in 4th and at one point it lost power, eased off and drove normally.
I thought fuel cut only happened on Stage 2 with a Intake and TBE due to the extra air and the HPFP not being able to cope...
 :confused:
Trying to borrow a Vagcom to log the blocks mentioned in other posts but has anyone else had this with a stage 1?
Car is running 240bhp so thought it would be ok. Going to do the 3rd gear test (2,000rpm - floor it to 6,000rpm) and see if it happens again - if it;s consistent then at least I can log it.
Just hope it's not something I did when servicing......wouldn't have thought so.
Offline alexperkins
  • -Receive: 99
Re: Fuel Cut on Stage 1???
« Reply #1 on: April 11, 2011, 02:13:12 pm »
Could be a damaged DV
Offline johnhol78
« Reply #2 on: April 11, 2011, 02:19:01 pm »
It's only about 2000 miles old..... :confused:
Offline alexperkins
  • -Receive: 99
« Reply #3 on: April 11, 2011, 02:19:36 pm »
Rev D?
Saint Steve
« Reply #4 on: April 11, 2011, 02:24:14 pm »
Try turning off your ESP and see if it stops matie  :wink:
Offline johnhol78
« Reply #5 on: April 11, 2011, 02:24:25 pm »
Rev D?
Yep.....car has been perfect up until today....too coincidental I did a service yesterday??
Was great with pipercross panel...though after oil and filter change and spark plugs this has happened.....
 :sad1: :sad1: :sad1: :sad1:
Offline johnhol78
« Reply #6 on: April 11, 2011, 02:25:24 pm »
Don't thkink it was trying to spin in 4th.... :wink:
It only cut midway (maybe further) up the rev range.
Offline alexperkins
  • -Receive: 99
« Reply #7 on: April 11, 2011, 02:32:24 pm »
My reply didnt save dammit lol
Anyway, check that your sparks are all in securely and the coil packs are also snug on top
Its also worth checking to make sure the MAF plug is in properly and that the side air feed is snapped onto the airbox properly.
Offline johnhol78
« Reply #8 on: April 11, 2011, 02:38:24 pm »
sh*t....can't remember connecting the MAF sensor back up  :ashamed:
Leaving work to check now.
Offline johnhol78
« Reply #9 on: April 11, 2011, 02:46:45 pm »
Nope sensor connected......hope it was that then.
When I chnage the plugs I nipped then up though not over tightened them. The coilpacks when on and I couldn't push them down anymore....do you need to use some force with them?
Offline alexperkins
  • -Receive: 99
« Reply #10 on: April 11, 2011, 02:47:51 pm »
So the sensor was or wasnt connected  :signLOL:
They have to be torqued to about 25nm
Offline johnhol78
« Reply #11 on: April 11, 2011, 02:48:03 pm »
Whicc part is this? if it's the tube where the MAF is then it's on properly.
Offline alexperkins
  • -Receive: 99
« Reply #12 on: April 11, 2011, 02:48:29 pm »
left side. ah kl
Offline johnhol78
« Reply #13 on: April 11, 2011, 02:48:47 pm »
Sensor was on....will get a torque wrench and double check..
Offline alexperkins
  • -Receive: 99
« Reply #14 on: April 11, 2011, 02:49:31 pm »
What plugs did you use also?
