Author Topic: A Sachs performance Clutch with an LUK Flywheel?  (Read 8384 times)
Offline Edition_30_P
  • Edition 30 P
« on: April 16, 2011, 07:26:24 am »
As per title does anyone know if This is ok to run on the Car? My mate does the same on his 2007 S3 with know problems but, not sure if it will be ok to do so on my ED30?
Can anyone shed some light on this please?
Thank you in advance!
Phil
« Last Edit: April 16, 2011, 08:11:53 am by Edition_30_P »
MK5 Golf GTI Edition 30|APR Stage 2+|Milltek Non Res TBE Decat|ITG Intake| Forge Twintercooler|Autotech HPFP Internals|Forge DV|R8 Oil Cap|AP Coilovers|WALK Kit|ECS Dog Mount| THS Mounts|Eibach F&R Anti Roll Bars|Sachs Uprated Clutch
Re: A Sachs performance Clutch with an LUK Flywheel?
« Reply #1 on: April 16, 2011, 08:47:56 am »
It's fine mate
Offline markymark
« Reply #2 on: April 16, 2011, 09:47:11 am »
It's fine mate
I would have to disagree, I ran this on my previous GTI and it still slipped and made a very loud wobble sound on tick over. VWR removed it and said they no longer change the clutch only, it should be mated up with the Sachs flywheel.
« Reply #3 on: April 16, 2011, 09:57:40 am »
You can disagree but I ran this set up for over 40k so I know full well how much this works  :P I only started to get slip once I had the diff fitted as the car had suddenly got all the grip it never had so I then changed to the full race set up  :P. If I was you I would put the full kit in as the box is out so you might as well
« Last Edit: April 16, 2011, 10:00:32 am by MAT ED30 »
Offline markymark
« Reply #4 on: April 16, 2011, 10:00:20 am »
I'm only going by what I experienced and listening to the advice of Matt and Simon at VWR. :happy2:
« Reply #5 on: April 16, 2011, 10:02:13 am »
I know mate I think I shocked them how long I had been on that set up
Offline gazbutS3
« Reply #6 on: April 16, 2011, 06:20:22 pm »
I've bin runnin a sachs plate and cover with an LUK flywheel for 10K on stg 2+ with no issues at all :happy2:
  • Edition 30 P
« Reply #7 on: April 16, 2011, 06:50:07 pm »
Thanks, for the reply guys! I'm going to try this match and hope it goes ok! I only seem to see cheap LUK flywheels at the mo!
Offline markymark
« Reply #8 on: April 16, 2011, 08:16:25 pm »
Ahhhhhh that might have been what VWR were saying, they won't sell the clutch plate without the cover plate now! :ashamed: As you were! :innocent:
« Reply #9 on: April 16, 2011, 08:17:27 pm »
:P  :rolleye:
Offline markymark
« Reply #10 on: April 16, 2011, 08:20:22 pm »
:P  :rolleye:
In my defence there was no mention of the cover plate until Gaz mentioned it! :P then it jogged my memory....come on it has been 6-8 months since I discussed this with Matt. I am getting old! :ashamed:
« Reply #11 on: April 16, 2011, 08:21:27 pm »
i know mate i am as bad  :rolleye:
Offline martziniuk
« Reply #12 on: April 16, 2011, 11:06:23 pm »
New LUK flywheel & Sachs clutch with no probs here  :happy2:
