Author Topic: Oil Usage  (Read 12760 times)
Offline Madman1886
Oil Usage
« on: May 27, 2011, 01:15:40 pm »
Ive got a 2008 GTi and ive noticed its using quite a bit of oil. It was quite low a few weeks ago so topped it up and checked it again yesterday and its about 4mm lower than it was then without the car getting driven very hard at all. The car seems to be running well and is pulling fine in all gears. Also noticed a small bit of emulsion under the oil filler cap but the car isnt running bad and isnt losing any water or pressurising the water system so presume the head gasket is ok
Anybody noticed this on their golf or has any ideas about why its chewing up oil?
Any help greatly appreciated
Gee
Offline Cooper
Re: Oil Usage
« Reply #1 on: May 27, 2011, 01:21:26 pm »
I believe VW say that 1 litre of oil per 10,000km is normal
C63
SQ5
Re: Oil Usage
« Reply #2 on: May 27, 2011, 02:01:35 pm »
Yup. Remember that's 600 miles!
TBH I wonder how much it's down to how the car is run in.
Offline Richn83
  • -Given: 49
  • -Receive: 86
Re: Oil Usage
« Reply #3 on: May 27, 2011, 03:27:21 pm »
The white emulsion is from lots of short journeys and not fully getting the engine up to temperature leaving moisture condensating around the filler cap.  Looks a bit like this?
Re: Oil Usage
« Reply #4 on: May 27, 2011, 04:02:22 pm »
To get rid of the moisture, go for a decent (at least 30 mins) drive, with plenty of welly.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 249
Re: Oil Usage
« Reply #5 on: May 27, 2011, 04:07:42 pm »
Mine uses a litre every 2000 miles
Offline parks
  • Red ED30 No. 1778 Detailing World member
Re: Oil Usage
« Reply #6 on: May 27, 2011, 04:52:53 pm »
Just bought 4 litres from opie to transfer into a 1 litre bottle, partially filled, in the boot. for when that light pops up  :happy2:
Standard: Rear parking sensors, Parrot Bluetooth
Retro fitted: MFSW buttons, RCD510, Boot pop, Black Monza II, Xenons, Audi jacking points, open fog light grills.
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
Re: Oil Usage
« Reply #7 on: May 27, 2011, 05:00:19 pm »
My 08 was using a litre every 2500 miles until it reached around 22k, since then it hasn't used a drop. I recall others with pretty much the same story. So it is possible that your oil consumption will reduce over time.
To echo the rest, as long as you use less than 1 litre per 600 miles, you're within tolerance. Plus the cheapest place I know for top up packs of Castrol Edge VW spec is Asda, £10 for 1 litre.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 249
Re: Oil Usage
« Reply #8 on: May 27, 2011, 06:16:54 pm »
Mines on 41k now and isn't using any less.  :ashamed:
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 249
Re: Oil Usage
« Reply #9 on: May 27, 2011, 06:18:21 pm »
Asda has put the price up now to £12
Offline Madman1886
Re: Oil Usage
« Reply #10 on: May 27, 2011, 07:22:45 pm »
Thanx guys, was begining to panic a bit with the emulsion under the cap but it looks exactly like that in the pic, car usually only gets driven to and from work bout 20 min drive but does get a boot now and again, next is gonna be the remap, see if it chews more then lol
  • -Receive: 453
Re: Oil Usage
« Reply #11 on: May 27, 2011, 07:38:15 pm »
Do not wait for the oil pressure light to illuminate before checking your oil level as by that time you may already have incurred engine damage.
Re: Oil Usage
« Reply #12 on: May 27, 2011, 08:07:40 pm »
+1. I check my oil level at least on a biweekly basis if not weekly. Also a good opportunity to check everything including washer flui (I go through bottles of the stuff!).
Offline ub7rm
  • -Given: 35
  • -Receive: 43
Re: Oil Usage
« Reply #13 on: May 28, 2011, 10:39:35 am »
To be fair there are two lights, oil level and oil pressure.  If its the oil pressure light then yeah you're in big trouble but when my oil level light comes on its pretty much always around the half way between the min and max marks.
Mk1 dipstick is still the best way though, just don't want to panic people!  :happy2:
Sepang Blue S4 BE Avant
Offline martziniuk
Re: Oil Usage
« Reply #14 on: May 28, 2011, 11:09:05 am »
My light has never come on and I've been down to minimum mark.
