Author Topic: Forge Twintercooler with Revo Stage 2  (Read 11422 times)
Offline Carrera2RS
Re: Forge Twintercooler with Revo Stage 2
« Reply #15 on: July 04, 2011, 05:56:47 pm »
I have taken the twintercooler off, why ?
Well I found the mapping for stage 2 better with no additional cooler, it does not feel quite as strong in the mid with it removed but a little crisper. I also did not want to move to Stage 2+ as I am just fitting VWR front brakes and I feel 300-315 hp is enough.
I suspect the twintercooler works best with more boost and a higher stage of tune, I was going to fit a THS but, there seemed no point unless you want to go beyond stage 2. My exhaust gas temps do not warrant an additional cooler.
It will be in the adds with pictures tonight  :happy2:
Offline PDT
  • -Receive: 142
« Reply #16 on: July 04, 2011, 05:58:18 pm »
Its intake temps the cooler helps with, not exhaust gas temps.
Offline Carrera2RS
« Reply #17 on: July 04, 2011, 08:08:12 pm »
 Your probably right
Offline Janner_Sy
  • -Receive: 113
« Reply #18 on: July 04, 2011, 10:55:59 pm »
Your probably right
not probably, definitely.  The cooler lowers inlet air temps
Offline Carrera2RS
« Reply #19 on: July 05, 2011, 04:48:43 pm »
I am well aware that this lowers intake temp, it is the point of an intercooler !
This will reduce initial combustion temp and hence reduce the likelihood of knock, I can see why EGT's might be lower on the same boost, timing settings. Unless ofcourse the final combustion temp is not materially different.
Offline Janner_Sy
  • -Receive: 113
« Reply #20 on: July 05, 2011, 08:59:00 pm »
. My exhaust gas temps do not warrant an additionalcooler
Colio, that's the only reasoi posted as you seemed a little confused :happy2:
Offline Carrera2RS
« Reply #21 on: July 05, 2011, 11:15:35 pm »
I might have got confused as it seemed that high EG temps were an issue on highly tuned cars and I think I read that additional intercooling helped.
I do think I might be a little down on midrange HP going back to no twintercooler, but the Stage 2 Revo map does seem to be crisper overall with the stock intercooler and it revs more cleanly past 6,000 as well.
My current settings are modest at 6,5,9 but I like it !
