Author Topic: Shark performance stage 3 results  (Read 10486 times)
Offline _Nathan_
    • Race Data Systems - Motec Cosworth Aim Racelogic
Re: Shark performance stage 3 results
« Reply #30 on: June 08, 2011, 07:20:53 pm »
Yes, will head out and do some logging, just a set of logs as listed on the APR site required?
Need to find a quiet private road for 4th gear pulls  :happy2:
Also assume that throttle just to the detent on the pedal to avoid kickdown is the correct way to do it?
E90 M3, E46 CSL Race car
  • -Receive: 453
« Reply #31 on: June 08, 2011, 07:46:02 pm »
For logging I would run the car in manual mode.
Offline heavyd
  • -Receive: 29
« Reply #32 on: June 08, 2011, 08:00:58 pm »
Have it in 3rd gear, then change to 4th, but keep the paddle pressed in, then floor the throttle with the paddle constantly pressed. If u don't keep paddle in, when you floor throttle, it will change down a gear by itself.
I would persevere with Revo, get in touch with Revo hq, and try and persuade them to sort it out before you start swapping tuners, might have to drive to their hq, you might be lucky and get it sorted :happy2:
Offline _Nathan_
« Reply #33 on: June 08, 2011, 08:19:45 pm »
Having the paddle constantly pressed was the bit I was missing, thanks.  :happy2:
« Reply #34 on: June 08, 2011, 08:36:09 pm »
The funny thing is, I don't think Hurdy had that problem (and I run the same settings on the same car, just a different fuel pump, I/C and Intake) so perhaps it IS a problem with something that goes with the map.
Only times I've had a cel was at Spa in Belgium and then initially after I had the decat fitted.  :happy2:
« Reply #35 on: June 08, 2011, 10:12:01 pm »
You can do it either way Nathan.
Manual mode in either case, press until the stop but not to the floor or change up and hold the upshift lever and press the throttle. :smiley:
Offline _Nathan_
« Reply #36 on: June 14, 2011, 04:08:43 pm »
Smoke test done on inlet side - no leaks.
Removed Revo completely and back to OEM VW code to see what happens...
Offline heavyd
  • -Receive: 29
« Reply #37 on: June 15, 2011, 12:48:43 pm »
If it was anything like mine, you wont get any CEL on anymore.......
Did some datalogging today, car certainly isnt on MBT anymore :scared:
Offline PDT
  • -Receive: 142
« Reply #38 on: June 15, 2011, 05:21:49 pm »
Looks ok, holding requested boost nicely and plenty of fuel in there to cope with the high numbers in the ignition advance. Could easily take a good 3-4 degrees out of the map without sacrificing any power or response.
