Author Topic: What did you and your MKV do today?  (Read 4026708 times)
Offline skkane
« Reply #12855 on: June 04, 2025, 03:26:07 pm »
Upshift paddle was unresponsive, cleaned contacts and swapped the stick on extensions with some that replace the original paddle caps. Much nicer IMO.
2007 ED30
Offline Marticus
« Reply #12856 on: July 03, 2025, 03:30:49 pm »
Looks fantastic! If you don't mind sharing can you let me know where you got the paddles from? Mine are worn and new replacements are unavailable or expensive, if I can do as you did and clean up the connections and replace the paddles it will be a big help!
Offline skkane
« Reply #12857 on: July 03, 2025, 08:54:53 pm »
I got them from here: https://www.aliexpress.com/item/1005006821485910.html?spm=a2g0o.order_list.order_list_main.5.32b31802RaDno8
Used this post as a guide for cleaning the paddle contact points: https://www.vwvortex.com/threads/dsg-paddle-shifters-working-intermittently-implausible-signal-in-vcds-fix-inside.6915231/.
You have to clean those 3 solder points. It will shift perfectly again after and the vcds error on the paddle will be gone. BTW... the lot of work part he mentions is not true, you open the paddle very easily with a sharp tool, like popping out the telescope on a watch bracelet link.
« Last Edit: July 03, 2025, 08:58:33 pm by skkane »
2007 ED30
Offline Marticus
« Reply #12858 on: July 03, 2025, 08:57:54 pm »
Thanks friend, much appreciated!
Offline Marticus
« Reply #12859 on: July 28, 2025, 09:31:18 pm »
With thanks to skkane.
Offline skkane
« Reply #12860 on: July 30, 2025, 08:40:39 pm »
Looks great  :happy2:
2007 ED30
Offline rxpx69
« Reply #12861 on: August 06, 2025, 04:54:00 pm »
Swapped in a Gen3 steering rack with all the fancy new bolts to finally! Stop the car from having a knocking noise over bumps at slow speeds and to hopefully resolve an inch of free play in the steering wheel.
Fixed the knocking noise, but the steering still thought it was in a trust fall exercise - turned out the column was to blame. Swapped that too, and finally got proper steering feel! Celebrated by accidentally karate-chopping the rear view mirror clean off the windscreen. Fun times.  :jumping:
Offline ZoliWorks
« Reply #12862 on: August 12, 2025, 08:39:58 pm »
After my old, stock front rotors got so warped that I couldn't drive faster than 140kph, I've finally decided to go all in and upgrade to S3 345mm brakes. Got a set of painted and refurbed calipers, bought some tools for the job and went ham. Rears will come later this summer.
Not only do they look much better, they fixed some of my steering wheel vibrations and the brake intensity improved quite a bit.
Mk5 Jetta 2.0 TFSI BWA | Manual | Mk6 GTI Front | BorgWarner K04 Turbo | Sachs X-Tend Clutch Kit | Ta-Technix Air Intake | Milltek Catless Resonated Exhaust | Ta-Technix Sandwich Intercooler | OEM S3 Injectors | Vis Motorsport 175 bar HPFP | 319hp 491nm
Offline mjmallia
  • -Receive: 60
Mike
South Coast
Offline ZoliWorks
« Reply #12864 on: August 13, 2025, 11:47:38 am »
I'm definitely getting the rear ones as well, but a bit later cause this went way over budget. I'll be fitting braided lines too when I add the rears. I wanted to see how it'll feel with the S3 rubber lines first. Good find on the brake clips, I'll deffo look into them.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=6apjqu439q1vl2aqe2jku70b8r&/topic,90967.msg917089.html#msg917089
« Reply #12865 on: August 26, 2025, 08:56:26 pm »
Got a new engine cover and oil cap.
Three screw holes were snapped and the top had been cracked since I bought it.
05 | Tornado Red | DSG
Offline Bassman1974
« Reply #12866 on: August 27, 2025, 02:36:52 pm »
Ooft,
That's lovely. Where did you purchase the replacement?
Offline Bassman1974
« Reply #12867 on: August 27, 2025, 02:48:48 pm »
BCS Prestige Turbo back and skyline tail lights on. Removed the Oettinger number plate surround since this pic was taken, and fitted a plain black frame.
Offline Bagus
« Reply #12868 on: October 15, 2025, 04:30:25 pm »
Got a bit carried away buying suspension parts….just got to fit them now..
Offline Jons1001
  • -Given: 22
« Reply #12869 on: October 16, 2025, 12:43:57 pm »
Impressive! I’m looking to do similar soon, don’t suppose you have a list of part numbers/prices?
