Author Topic: What did you and your MKV do today?  (Read 3568113 times)
Offline gulfstream11
« Reply #195 on: August 05, 2011, 12:23:20 pm »
Oi..Get in line... My brake sensor loom first!!!  :P
« Reply #196 on: August 05, 2011, 05:37:11 pm »
Back of the queue you for not coming and saying hello when I had the car detailed  :mad:
 :signLOL:
Offline StuF
  • -Given: 31
  • -Receive: 38
« Reply #197 on: August 05, 2011, 06:18:28 pm »
Had my rear end vandalism repaired by ChipsAway
Truly impressed by the standard of their work
« Reply #198 on: August 05, 2011, 07:05:42 pm »
 :signLOL:
I was on Holiday ya tourist.. :booty:
« Reply #199 on: August 05, 2011, 07:12:12 pm »
 :signLOL:
Hmmmm, let ya off then  :grin:
Offline GLIDN
« Reply #200 on: August 06, 2011, 11:53:32 am »
Thanks to APR NZ. For lending me their hoist today, not too mention helping with my car from 8am-8pm.
Went to re-install my Downpipe. Ended up snapping off two bolts on the turbo.
So redrilled and tapped them. If this ever happens again, the turbo will be pulled off for this to be done.
Way too hard to do it attached to the engine.
Installed APR HPFP, went to stage 2+.
installed WALK KIT. That is a highly recommended upgrade for any mk5/mk6 owner.
Went to go install my bilstein PSS9 kit. Turns out one of the front shocks bound/rebound adjuster is damaged.
But that's not the worst, the adjuster are gone. But worst off all the spring caps for the front shocks are missing too.
So gave up on that idea. Will return them and just get H&R lowering springs instead.
Also installed a Downpipe and Stage 2 Tune on a MK6 GTI.
Offline Frenzy
  • -Receive: 29
« Reply #201 on: August 06, 2011, 01:02:40 pm »
Just given her a hose down and then a wash with Megs #62 shampoo  :party:
The good stuff: she's clean and already looking much better.  :jumpmove: The bad stuff: getting her clean has shown up the blemishes, there's one odd circular dotted series of tiny scratches in the DSR door  :sick:
Just debating whether the rain will hold off, so i can then clay, wash, polish, gloss and finally wax. Also debating whether i have enough time to do all that before the Mrs kills me for neglecting her and our son  :grin:
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
« Reply #202 on: August 06, 2011, 07:31:33 pm »
Done lots and lots today!! Il get some pictures up on my build thread!
Offline Frenzy
  • -Receive: 29
« Reply #203 on: August 06, 2011, 08:29:02 pm »
Rain held off (just) but i didn't have time to go through the full detailing process so after washing the car and going for a walk with the Mrs and our lovely little boy, i followed up with a bit of Megs Final Inspection, Rain X for the exterior of the windows/windscreens and Auto Glym glass polish on the lights and the inside of the windows/windscreens.
I'll post up some pictures in the detailing section as results aren't bad for a "quick" effort  :laugh:
Had to b :scared: ll :scared: ck the cat for jumping on the car twice - she's put some small scratches into it  :sad1: hopefully they'll be sorted when i work on it next time after a polish  :rolleye:
« Last Edit: August 06, 2011, 08:31:00 pm by Frenzy »
Offline big al
« Reply #204 on: August 06, 2011, 10:34:15 pm »
Very bravely cut up 2 rear bumpers, one of them an R32 one  :surprised: in order to plastic weld it into a US spec one with a shortened recess.
Pics to come shortly in my build thread.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #205 on: August 07, 2011, 09:28:23 am »
Adjusted the actuator to crack open the wastegate at 7.5 psi which caused turbo flutter at around 23 psi from 3k rpm to 4k rpm. Then the boost peaked at 27 psi and ran 23 psi to red line. With over boost causing the turbo to flutter, I decided to back off a bit with the actuator but went too far. It is again back into lag from 2k rpm to 3k rpm, but is 2 to 3 psi stronger than it was in the beginning. So I will tighten the actuator up again, but just not as far as I did when I caused the flutter and over boost. Monday = Fixed = hopefully. Also, it ran consistently .4 seconds quicker in the 1/4 mile this week than it did last week.
« Reply #206 on: August 07, 2011, 09:37:26 am »
Packing her for the mission that is Doncaster to Detmold. . .
Would rather be washing her prior to Vw fest but the ferry is booked :(
« Reply #207 on: August 07, 2011, 09:56:01 am »
Yesterday: trekked to halfrauds to buy a new tax disc holder tax disc holder repair kit because I lost the silly allen key that came with the holder, presumably when I recently cleaning the interior.
Today: Gave it a bit of a scrub.
Offline Nickyboy
  • 2007 ED30 in Grey
« Reply #208 on: August 07, 2011, 02:01:43 pm »
Fell in love with it again after putting it up for sale. Keeping it  :driver:
Offline damoegan
« Reply #209 on: August 07, 2011, 02:48:52 pm »
I've prob got the right size allen key you could of had  :wink:
