Author Topic: painting vw badges  (Read 10652 times)
Offline candy turbo
painting vw badges
« on: April 13, 2009, 10:03:25 pm »
whats the best method of painting chrome vw badges ?  i m thinking acid etch primer x2 coats black x2 coats clear laquer x2 any one know any better ??????????
Re: painting vw badges
« Reply #1 on: April 13, 2009, 10:55:56 pm »
Plastidip seems popular in the USA.
Offline candy turbo
« Reply #2 on: April 13, 2009, 11:13:51 pm »
looked at that but its flexible ! so think its more like a rubber coating !!!
« Reply #3 on: April 13, 2009, 11:19:38 pm »
That is why they like it because it doesn't chip as easily as painted ones. The number of painted badges I've seen that are chipped in some way beggars belief. It then makes the badge look awful. It is okay to paint the rear badge as it doesn't get chipped, but I'd never personally go for painting the front.
Offline neg
  • gone old skool
« Reply #4 on: April 14, 2009, 09:50:42 am »
I have a painted one - matt black which I laquered and its lasted ok - few touch ups here and there. I did another at the time which is just matt black but I also have the CF one which I have not put on yet.
Paint is a quick and easy method but it wont last a great length of time - but then again doesnt cost much to do.
Method was to sand down to take the shine off and paint, do about 7 or so layers leaving 30-60mins inbetween.
Offline TurboTrev
« Reply #5 on: April 14, 2009, 10:45:22 am »
Just did my front VW badge yesterday.  Rubbed it down for about 30 seconds with some fairly smooth wet and dry to take the gloss off the chrome, cleaned it with thinners, sprayed it with a coat of plastic primer (halfords) and left it about 60 mins, then a coat of satin black (halfords).  Did the same on my previous GTI and it lasted 4 years.
Offline dan.payne
« Reply #6 on: April 14, 2009, 02:29:15 pm »
I used some halfords plastic primer and matt black for mine, no laquer as I wanted a matt finish to match the grille.
GTi Edition 30 Phase 2+ :jumping:
Offline pareet
« Reply #7 on: April 14, 2009, 02:44:33 pm »
is there a link/ guide on how to remove the front and rear badges so that you can paint them?
Black 2006 Mk5 GTI - 200bhp.
Offline dan.payne
« Reply #8 on: April 14, 2009, 03:44:26 pm »
Front one twists anti clockwise and pops out as for the rear see below:
http://www.golfmkv.com/forums/showthread.php?t=7601
Offline candy turbo
« Reply #9 on: April 14, 2009, 08:56:59 pm »
right , i rubbed mine lightly with fine wet n dry , applied 2 coats of u pol acid etch primer about an hour apart , rub lightly again with wet n dry ...... tomorrow have 2 coats of u pol gloss black followed by clear laquer till i get  fed up  ill show you the results when they are back on ......... :happy2:
Offline pareet
« Reply #10 on: April 15, 2009, 08:28:41 am »
thanks for that !! My front one doesnt twist at all ???? I dont have to remove the grille before i try and twist it right?
Offline TurboTrev
« Reply #11 on: April 15, 2009, 09:22:09 am »
Yes, poke your fingers into the gaps in the V and W and twist anti clockwise for about an inch or so.  You should then be able to wiggle it out.
Offline vwrascal
« Reply #12 on: April 16, 2009, 09:31:10 pm »
I'm gonna prize the little fec*er off and spray it at the weekend, but how about the GTI badge on the rear hatch? easy removal?
I'm guessing hot water and lots of patience, which I'm short of!   :mad:
Offline candy turbo
« Reply #13 on: April 18, 2009, 07:51:31 pm »
happy with my results , used matt black but gloss clear coat to finish ........
« Reply #14 on: April 18, 2009, 07:54:36 pm »
Job well done  :happy2:
