Author Topic: Data logging results - Bit concerned  (Read 4190 times)
Offline ktlstar
« on: December 22, 2011, 02:35:57 pm »
Hi all,
After gone and had Revo stage 2 installed the settings were applied as B9 T6 F7.
These are the logs i just came back with and should i be worried as i see -0.8 timing being pulled back.
« Last Edit: December 22, 2011, 02:39:01 pm by ktlstar »
- #1240 ED30 Revo STAGE2+
- Southeast - Vag Com owner
  • -Receive: 453
Re: Data logging results - Bit concerned
« Reply #1 on: December 22, 2011, 03:00:17 pm »
Your CFs look fine but you have a fuel cut mid range!  :scared:
Do you have an uprated hpfp? I would turn down the boost and check your cam follower asap.
« Last Edit: December 22, 2011, 03:04:36 pm by bacillus »
Offline ktlstar
« Reply #2 on: December 22, 2011, 03:06:44 pm »
I dont have a HPFP which conerned me why AMD put fuel at 7.
I have no switch to change boost or fueling.
I have HPFP and cam follower sitting right next to me however most places are shut, and dont fancy going back to AMD.
I was hoping someone local i.e Bromley/se london could lend me there switch or help me set it up.
« Last Edit: December 22, 2011, 03:09:03 pm by ktlstar »
Offline liver
« Reply #3 on: December 22, 2011, 03:22:43 pm »
deffo fuel rail issue, i wouldnt be worried about timing pull at all mate
i feel once the new pumps on it will be fine, not a hard job to do youself at all 30mins-1 hour tops
Offline ktlstar
« Reply #4 on: December 22, 2011, 03:34:24 pm »
Yeah, stupid of me i should of fitted it however the cam follower didnt turn up on time!
Offline PDT
  • -Receive: 142
« Reply #5 on: December 22, 2011, 03:38:52 pm »
Set fuel to 9. The timing pull is ine, nice low figures.
Offline ktlstar
« Reply #6 on: December 22, 2011, 03:38:59 pm »
1 of my first runs, the other 2 were just after this log.
Offline ktlstar
« Reply #7 on: December 22, 2011, 03:41:48 pm »
PDT - thank you for your input.
I wish i could set fuel to 9 however i dont have no switch to do so  :sad1:
What you mean by timing pull is 'ine' ?
Thanks all
edit : fine ?
« Last Edit: December 22, 2011, 03:44:02 pm by ktlstar »
Offline PDT
  • -Receive: 142
« Reply #8 on: December 22, 2011, 03:57:03 pm »
ine= fine  :laugh:
Offline ktlstar
« Reply #9 on: December 22, 2011, 04:12:29 pm »
Thats sound, so really Fuel pump needs to be fitted. Thats cool, I'll try and get that fitted over the holidays and then try and do some more logging.
With the CF values, you all put my mind to rest.
Thank you guys
 :santa:
Offline martziniuk
« Reply #10 on: December 22, 2011, 09:35:38 pm »
Do Revo stage 2 maps request 129.9 bar? Most stage 2 maps request 109.9 don't they?
Offline ktlstar
« Reply #11 on: December 22, 2011, 11:29:23 pm »
From JKM
The JKM K04 Stage 2 package is for owners of 2.0 TFSI engines who want the ultimate tuning package for their K04 TFSI engine. This package utilises market leading REVO Stage 2 software and when combined with the hardware in this package it will enable the K04 turbo to flow enough air to produce maximum engine torque & power.
Please note that Revo K04 Stage 2 software requests 129.99Bar fuel pressure as per a K03 stage2+ file.
If requested, Revo K04 Stage 2+ software can be added to this package at an extra £50+vat - contact JKM.
Sorry for another question guys..... Because the pump cant keep up, how dangerous is this for the engine ?
« Last Edit: December 22, 2011, 11:31:37 pm by ktlstar »
  • -Receive: 453
« Reply #12 on: December 23, 2011, 08:19:00 am »
Could you clarify if you have a k03 or k04 and is it a stage 2+ or 2 map?
If your pump can't keep up then you can get an engine check light and the car going into limp mode. For the time being keep off the boost and you should be ok till you get your fuelling sorted.
Offline liver
« Reply #13 on: December 23, 2011, 08:29:25 am »
car is a K04 and its stage 2 map
once the uprated pumps on im pretty sure it will be spot on
he is also waiting for his select switch so untill that comes he cnt change any settings
might be worth seeing if there is anyone local with one
Offline ktlstar
« Reply #14 on: December 23, 2011, 08:49:15 am »
Thanks Mark -
I was going to attempt the pump change today as i got 6 hours to spare.
Yep thats right still no switch, and should i be angry at the company that put them settings in ? IFF i do go back i will make a slight complain and maybe provide pictures just to show them.
Iv already asked Mark ;)
Cheers though mate
