Author Topic: DanGB's Leon Sport TFSI 4WD Sleeper - The End  (Read 128717 times)
Offline DanGB
  • Different
Re: DanGB's Leon Sport TFSI Sleeper - *4WD conversion = Done*
« Reply #240 on: June 17, 2013, 09:28:39 am »
Great vid you seem to be backing off a lot though dude?
There were some moments before some turns where I was hitting the limiter and just couldnt be bothered to change up a gear, as it was so close to the next corner. For example, the main straight I could get into 5th, but only for a short while, so just let off until breaking time. My gear changes in my car arnt the smoothest so thats why  :smiley:
« Last Edit: June 17, 2013, 09:33:25 am by DanGB »
Seat Leon Mk2 TFSI sport 4WD sleeper - Breaking
Buld thread: http://www.mk5golfgti.co.uk/forum/index.php/topic,45377.0.html
Offline DanGB
  • Different
« Reply #241 on: June 17, 2013, 09:30:36 am »
So, you are in a prime position now to say whether or not you believe FWD or AWD is better on track?
Awesome vid too Dan. Liking the commitment on some of those turns. :driver:
For my car its 100% better. now you can use ALL the power, as before, coming out of turns, it would wheelspin in the lower gears, even with the Peloquin diff installed.
Im not a good enough driver to judge other factors yet.
Offline DanGB
  • Different
« Reply #242 on: August 12, 2013, 09:43:51 am »
Well, cars been off the road for ages since a track session at btands hatch 3 months ago.
Had an elusive oil leak, then an elusive boost leak.
Boost leak turned out to be the wastegate rod had disconnected from the watsegate. Impossible to see without the subframe off.
Was at 30-130 yesterday and had the car weighed. A good result of 1400kg without driver and 5/8 full tank of fuel.
Thought that was pretty good considerinf its standard wheels and road trim inside.
Offline mk_boy85
« Reply #243 on: August 12, 2013, 08:36:04 pm »
Hi. I'm majorly impressed with this. I'm currently building my golf into the same as yours. Got a few questions. Can you tell me where you got you centre bracket mounts from and could you put me in touch with the guy who wired your 4wd ?
Thank craig
Offline DanGB
  • Different
« Reply #244 on: August 14, 2013, 09:39:06 am »
Thank craig
Hi Craig,
the parts were bought as a package (im not sure of the origin though).
By centre bracket mount, do you mean the propshaft mount half way long the transmssion tunnel? This is a standard part so you can buy this or poick it from a scrappy. The mounts are also standard I beleive and were welded on.
The install was done by a couple of greek guys that came over, who were knwn to APR, but I dont have there contact details, and they didnt speak much english.
What information are you after?
Offline DanGB
  • Different
« Reply #245 on: August 16, 2013, 11:30:17 am »
Car's been feeling a bit sad lately, what with the oil and boost leaks, so i'd thought i'd give it some love with a new headunit. And of course it has to be OEM with my car.
I trieated it with an RNS510 version H, quite quite new, with 4020 firmware.
I previously had an RNS510,version A, years ago, but was pretty horrible, due to imcompatiblities with the unit, and other things about the unit which were crap or I dont link, but 6 years alater its all good :)
I changed the colour scheme of the unit, so the media pages are red instead of white - so its a bit less distracting when driving at night. The nav pagesa are a very dark blue which is nice.
I also changed the VW boot up logo to the SEAT one using an easy tool:
Offline Janner_Sy
  • -Receive: 113
« Reply #246 on: August 16, 2013, 12:19:43 pm »
That makes the dash look a million times better  :happy2:
Offline Bignod00
  • Ginsters are sh*tE!!
Re:
« Reply #247 on: August 16, 2013, 02:31:28 pm »
Which tool did you use to change the boot screen Dan? I've got the version H also and couldn't get any I tried to work! :-(
Offline DanGB
  • Different
« Reply #248 on: August 16, 2013, 02:50:15 pm »
what problem did you have?
I used this:
http://www.netdata.be/iso/?action=about
Offline Bignod00
Re:
« Reply #249 on: August 16, 2013, 02:52:58 pm »
Thanks matey, the weird thing is that's what I used too! It just would'nt read the disk!
I tried, DVD + & -, CD and two different burning programs!
Offline DanGB
  • Different
« Reply #250 on: August 16, 2013, 02:55:20 pm »
Yes, it says CD error, then some other error. You have to go into firmware downgrade mode to do it.
Its a certain key combination that I cant remember right now.
Offline DanGB
  • Different
« Reply #251 on: August 16, 2013, 02:58:54 pm »
I think Setup + Star + Eject will reboot in into firmware downgrade mode and read the CD.
Offline Bignod00
Re:
« Reply #252 on: August 16, 2013, 03:01:22 pm »
Yeah matey, tried that too. It went into the updates mode then just spat the disk back out again! I got angry so gave up in the end, may try again now I know you've done it on a H also! :happy2:
Offline DanGB
  • Different
« Reply #253 on: August 16, 2013, 03:03:11 pm »
Cool, if all else fails I will send over my CD (if you want that logo)  :happy2:
Offline Bignod00
Re:
« Reply #254 on: August 16, 2013, 03:08:29 pm »
Thanks matey, your a star! :happy2:
I'll give it another go this weekend as I'm changing my cam follower too and let you know if I sort it!
