Author Topic: DanGB's Leon Sport TFSI 4WD Sleeper - The End  (Read 128737 times)
Offline Bignod00
  • Ginsters are sh*tE!!
Re:
« Reply #255 on: August 16, 2013, 03:45:21 pm »
Damn it!! Just gone out to try it and my battery is totally dead! Bloody RNS!
Offline DanGB
  • Different
Re: DanGB's Leon Sport TFSI Sleeper - *4WD conversion = Done*
« Reply #256 on: August 16, 2013, 03:57:27 pm »
oops, do you have the newer CAN gateway?
Seat Leon Mk2 TFSI sport 4WD sleeper - Breaking
Buld thread: http://www.mk5golfgti.co.uk/forum/index.php/topic,45377.0.html
Offline Bignod00
« Reply #257 on: August 16, 2013, 04:37:32 pm »
I'd hope so matey as its a 58 plate car? Gotta scan it and find out.........now to find someone with VCDS near me. :sad1:
Offline DanGB
  • Different
« Reply #258 on: April 23, 2014, 11:01:06 am »
Well, about time I updated this.
Its was away/broken since October last year. The turbo broke - not only did the bearings start going, there was also a pretty epic crack in the housing.
So, it was 'upgrade' time. Went for a GTX2867 as per the APR Stage 3+ GTX kit. About the same top end, but noticeably better spool up.
As part of the upgrade, also got a new Carbonio closed air intake, and APR 155bar fuel rail valve, and a new fuel rail pressure senor to let a bit more fuel through.
Gearbox was also 'rebuilt' at AKS, not much needed doing really, just replacing a few minor cheap bits, more preventative work, whilst it was apart.
Then it went over to VRS Northampton. Needed a new N75 valve, gear linkage cable needed replacing, and most of all, the ESP needed sorting.
Since having the 4WD, the ESP has never worked properly. But after many days of fault finding, it was traced to a dodgy wire, and one of the sensors upside down, and now its perfect"
Oh, still has a minor water leak, and possibly oil leak still   :signLOL:
« Last Edit: April 23, 2014, 07:30:35 pm by DanGB »
Offline toosmiles
  • -Given: 22
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,92286.0.html
Re: DanGB's Leon Sport TFSI 4WD Sleeper - *Update 23/4*
« Reply #259 on: April 23, 2014, 11:09:48 am »
cant beleive ive only just seen your car m8
what an awesome build thread and car
nice to see something 'built' than bought :happy2:
Golf R mk6 R-tech tuned GTX3071r
« Reply #260 on: April 24, 2014, 12:59:03 pm »
Excellent update Dan. Have you dyno'd it yet on the new set-up?
Offline DanGB
  • Different
« Reply #261 on: April 24, 2014, 06:46:44 pm »
Thank you John  :wink:
So, yes I did take it to R-tech for a dyno and logging session recently, as the car didnt quite feel as quick as it 'should' be.
Here is the graph:
Its pretty quick, but should be making 450hp with the Stage 3+ kit I have.
Strangely enough though, the APR map has switchable programs via the cruise control stalk, and I went to 'change' the map the other day to ensure it was on the '98 RON' map, and it indicated it wasn't for some reason! But there was no way of telling what map it was on. So perhaps it was only running on the 95RON map which I also have. (Wouldnt of been on the 104RON map as it would of been pulling back lots of timing).
There doesn't seem to be much difference though on a quick drive after 'changing' the map program.
There is a whole new map due in a free weeks too with new features like the motorsport limiter and new boost control, so that should be interesting to try. Will do a before and after dyno hopefully.
« Reply #262 on: April 25, 2014, 11:26:53 am »
Mighty torque that has.  :happy2:
Offline DanGB
  • Different
« Reply #263 on: April 25, 2014, 02:28:54 pm »
Brake update time.
Ive had the AP Racing kit for nearly 7 years now, and they served me well.
It was the mk5 specific kit they do including 6 pot calipers, and 330x28mm rotors and bells. Extremely light weight.
Ive found though, especially recently they seem to be getting to hot, thus decreasing the life of the discs and pads.
So I'd thought I try something new:
I bought some second hand TTRS calipers from Ebay for £300, and also the TTRS fully floating 'upgrade' kit from Alex Kerr (made by Vagbremtechnic).
This includes:
-362x32mm Rotors.
-Custom bells
-Custom brackets
-HEL Braided lines
Also Picked up some Pagid Blue RS4-2 pads to go with this:
And here they are on the car after I fitted them:
I still needed my existing 10mm Spacers to clear the calipers though  :happy2:
« Last Edit: April 25, 2014, 02:30:40 pm by DanGB »
« Reply #264 on: April 25, 2014, 02:54:29 pm »
 :party: :party:
:love:  brakes
Offline Pikey Motorsports
« Reply #265 on: April 25, 2014, 03:02:19 pm »
How will those calipers conpare to the aps on track?
TSR PERFORMANCE GTX30 520BHP
LITCHFIELD R35 GT-R 660BHP
MSL E63 AMG 720BHP
HCP BM3 M5 800BHP
Offline DanGB
  • Different
« Reply #266 on: April 25, 2014, 04:07:32 pm »
I shall find out next weekend, with a few sessions at Lydden.
Seemed to have cooked my brakes last year at Lydden, was very hot though!
Offline DanGB
  • Different
« Reply #267 on: May 04, 2014, 06:57:41 pm »
Heres something you dont see very often.. Pictures of my engine bay:
Replaced the underbonnet soundproofing as the old one was all mouldy and saggy due to the common water leak problem.
To try and stop this problem this time, I painted the underside of it with rubberised paint.
« Reply #268 on: May 04, 2014, 07:02:55 pm »
What's on your relay box Dan?
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=4t8gnmer7nseprbh19od3662hd&/topic,19740.0.html
« Reply #269 on: May 04, 2014, 07:03:54 pm »
WMI controller?
