Author Topic: creaking from front  (Read 5157 times)
Offline mumf78
creaking from front
« on: April 04, 2012, 11:00:42 pm »
as above iv got some creaking from the front of my 2006 gt tdi over bumps . seems worse when the cars cold for some reason. iv read somewhere about top mounts if anyone can help?
Re: creaking from front
« Reply #1 on: April 04, 2012, 11:07:27 pm »
ARB bushes?
Offline mumf78
« Reply #2 on: April 04, 2012, 11:13:42 pm »
could be mike. il wait until winter goes away AGAIN and il get underneath and have a look! cheers for the input  :happy2:
Offline Matto
  • -Receive: 116
« Reply #3 on: April 04, 2012, 11:48:22 pm »
« Reply #4 on: April 05, 2012, 09:21:47 am »
If theyre still in good condition.  White lithium spray grease may help
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=iu8an52knc3selgrpq098d2a1o&/topic,19740.0.html
« Reply #5 on: April 05, 2012, 09:24:24 am »
More likely to be creaking top mounts.
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #6 on: April 06, 2012, 02:48:21 pm »
I get the exact same thing sounds like it comes lower down than top mounts from sub frame or arb area but could be top mounts.
« Reply #7 on: April 06, 2012, 03:30:54 pm »
New Top mounts & ARB bushes didnt solve mine.  Might have been my WALK as I have superpro inserts now
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #8 on: April 06, 2012, 03:49:17 pm »
I was wondering if it could be the stretch bolts on the sub frame having stretched a little allowing some play?
« Reply #9 on: April 06, 2012, 04:36:35 pm »
I want to use the new bolts & shims/spacers as a matter of course
Offline four!
« Reply #10 on: April 06, 2012, 08:03:18 pm »
I had this, turned out to be front lower arm front bush, they were worn. Creaked rather than rattled :)
Offline apples12
« Reply #11 on: April 07, 2012, 08:47:59 am »
toooo muuuuch technicallls....lol
do you mean that after you replaced the wishbone bushes the creaking disappeared?...
i've changed shock absorbers, top mounts and added lower engine mount insert on mine. next thing waiting to on is a full set of wishbones and bushes along with anti roll bar linkages...
MK6 GT TDI  - CW - LUX pack
GONE
MkV Golf 1.9TDI Sport in DBP, 160,000 miles and climbing!
Retrofits by me:GT front end,OEM bixenons with auto-levelling/washers, Valeo LED Rears, MFSW + Highline SWCM, Cruise Control, 30byte Highline CECM, Highline clocks, Rain/Light Sensor, Auto-dimming Rear view Mirror, RNS-510 LED (Ver H; SW: 4020), Fiscon Basic Bluetooth, MDI + Aux, Armrest, Reverse Camera LOW, TPMS..what next...
Offline four!
« Reply #12 on: April 07, 2012, 10:29:09 am »
Yes, on my car it was coming from the front bushes on the lower arm (not the console bush) The bush had separated but showed very little signs of free play. It left the steel sleeve with some rubber still attatched then the bit you would press into the arm itself also with some rubber attatched. Rubber moving on the rubber when dry made the creak. On a wet day it wasn't so bad.
Worth checking anyway.
Good luck
Offline cangli
« Reply #13 on: April 14, 2012, 04:44:40 pm »
My money would also be on the lower control arm bushes. There is a TSB for this here http://homepage.mac.com/alden/gti/TSB-40-08-01.pdf.
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #14 on: April 14, 2012, 05:35:26 pm »
Interesting tsb document cangli I guess that us orientated from the terminology, so it sounds like a compound issue on the rubber or plastic so I will probably just live with it as its not a wear and tear problem.
