Author Topic: Do all factory xenons come with headlight washers. *UPDATE*  (Read 7740 times)
Offline Nodz
  • -Given: 73
  • -Receive: 103
Re: Do all factory xenons come with headlight washers.
« Reply #15 on: May 17, 2012, 06:21:55 am »
As kalpsn2000 said, the bumper strips below your lights should be made up of 2 pieces, if not and they are only one piece then you haven't got headlight washers. If they are 2 piece the next thing to check would be the 20amp fuse (can't remember the fuse number) in the fuse box on the right hand side of the dash as with cold weather freezing the fluid lines can cause the fuse to blow when the washers are operated
Offline driver rider
  • -Given: 18
Re: Do all factory xenons come with headlight washers. *UPDATE*
« Reply #16 on: May 18, 2012, 05:49:48 am »
OP based on your sig you list heated seats which I thought was part of the winter pack which should mean you have the headlight washers also (I dont have either so correct me if i'm wrong).
Also you can tell from your bumper if you have headlight washers, the strip below the headlight will be split in to two bits.
EDIT:
Just noticed you have leather seats so they come heated as standard so my 1st point is probably moot.
Thanks. I have indeed got two bumper strips under the light.  Im very relieved at that. Hopefully this means I've got the headlight washers fitted.
Over the next couple of days I'll check the fuse. Thanks for such a helpful response.  Much appreciated.
Hi guys,
I had a play with some of the fuses in the car, I replaced a burnt fuse and now they work brilliantly!  I love them.  Thanks for all the help.  I really appreciate it.
« Last Edit: June 04, 2012, 05:33:43 pm by driver rider »
3 Door GTI Black, Cruise Control, DSG, Factory Tints, Folding Mirrors, Heated Seats, Highline Display, Leather, Monza II's, MFSW, Parking Sensors, Puddle Lights,  Xenons,
To be fitted....Bluetooth,DVB-T, MDI, RNS510, Stage one (opinions much appreciated)
