Author Topic: Which wheels will fit on my golf?  (Read 16041 times)
Offline tom619
« on: May 24, 2009, 04:19:47 pm »
hi there im going to be buying some new wheels soon but am lost as to what will fit and what won't as i dont particularly want to change the suspension, i know i need 5 studded wheels but what about diameter, rim width, offset, and also tyre width and aspect ratio?
for example i like these rims
http://cgi.ebay.co.uk/18-VW-MK4-R32-Style-Alloy-Wheels-Tyres-MK5-Golf-Audi_W0QQitemZ260411117631QQcmdZViewItemQQptZUK_CarParts_Acc_Wheels_tyres_Rims_Car_Wheels_ET?hash=item260411117631&_trksid=p3286.c0.m14&_trkparms=72%3A1683|66%3A2|65%3A12|39%3A1|240%3A1318|301%3A1|293%3A2|294%3A50
but will they fit on this?
Offline TomB
Re: Which wheels will fit on my golf?
« Reply #1 on: May 24, 2009, 05:00:21 pm »
Yeah, it says they will in the auction!
Tom
05 GTI - 18" Merc wheels, coilovers, colour coded Votex kit, all waiting to go on.
Offline gazbutS3
« Reply #2 on: May 24, 2009, 06:54:38 pm »
yes will fit spot on :happy2:
Offline Rich
    • Carpet Underlay
« Reply #3 on: May 24, 2009, 07:18:47 pm »
Mate these will fit perfectly  :happy2:
No need to worry :innocent:
Offline tom619
« Reply #4 on: May 25, 2009, 05:11:06 pm »
ah thanks, what do you think of the wheels on another note?
Offline SteveP
  • -Given: 117
  • -Receive: 341
    • My Project
« Reply #5 on: May 25, 2009, 07:03:43 pm »
They would look good in a darker colour on a silver car  :happy2:
Offline tom619
« Reply #6 on: May 25, 2009, 07:05:29 pm »
any particular example?
Offline tom619
« Reply #7 on: May 25, 2009, 09:28:38 pm »
also, i did a bit of research and found this guys post about how his wheels stick out too much, how can i avoid this in lehmans terms please?
link to the post http://www.golfmkv.com/forums/showthread.php?t=50195
« Reply #8 on: May 25, 2009, 09:42:04 pm »
Those wheels you posted earlier will fit perfect as others have said. I always do my sums based on the Monza and ed 30 size. Which is
7.5 inches wide and 51 offset.  Those wheels above are 8 inches wide so you have got to add 1/4 of an inch to the front and 1/4 of an inch to the back of the wheel,  so that is 1/4 + 1/4 = 1/2
So just on the wheel width alone you would be adding about 6and a half mil to how far the wheel sticks out.
Then you have to add the offset which was 45 that is 6 mil more than the standard monza 51 take away 6 mil gives 45 offset.
So add this 6 mil offset to your 6 and a half mil extra wheel width and you get approx 12 and a half mil of wheel sticking out further than the Monza which is perfect as they are sat quite far in the arch.  :rolleye:
I have some wheels coming soon which are about 18 mil further out, which is right on the border of fitting without any other arch alterations or camber.  :fighting2:
Offline Mark_GTIV
« Reply #9 on: May 26, 2009, 09:37:36 am »
I think you'll struggle there TC. I'm currently running 8Jx18 CH with ET50 on a 12mm spacer which equals +13mm further out than the Monzas (if my sums are correct) because the damn 8mm H&R spacers haven't arrived from TTS Roadsport yet  :sad: .
My car isn't as low as yours and I'm getting a small rub on compression, plus the wheel to my eye sticks out a touch too much.
Offline tony_danza
  • -Receive: 112
« Reply #10 on: May 26, 2009, 10:42:14 am »
ET42 18x8 225 tyre.
I've now got 2 big holes in my front arch liners and I've forgotten how many times I've had a rubber mallet to the arch lip because they've pulled it.... still, it was funny doing it!
I'm ditching the liners and having the arches rolled  :angry015:
Sideways yo!
Offline tom619
« Reply #11 on: May 26, 2009, 12:50:16 pm »
ok i have no idea what arch liners are and no idea what getting them rolled is lol! im just looking for a straight swap without the need to change anything else, and without potential rubbing, and that don't stick out much to void curbing lol what should i be going for?
oh and i read something about rim protectors what are these?
« Last Edit: May 26, 2009, 01:28:03 pm by tom619 »
« Reply #12 on: May 26, 2009, 05:08:15 pm »
I dont think your sums are correct Mark, you forgot to factor in the 1/2 inch extra wheel width which is a 1/4 inch to add to your total so yours at the minute are somewhere near 19 to 20 mil further out.  :happy2:
+ i have some camber adjust mounts to go on as well, as i fancy a bit off sump scrape.  :signIWS:  :laugh:
Offline gazbutS3
« Reply #13 on: May 26, 2009, 05:18:35 pm »
think your are correct TC :happy2:
« Reply #14 on: May 26, 2009, 05:20:11 pm »
Now there's a refreshing change.   :signIWS: :signLOL:
