Author Topic: Fitting a K04 intake to a K03 Engine  (Read 2957 times)
Offline Dan.b
« on: August 06, 2012, 10:25:58 pm »
I've got my eyes on a KO4 BSH intake but I've got a standard gti (ko3)
Can anybody tell me if it's possible and if so what is required.
Thank you.
Offline 56OctyVRS
  • -Receive: 72
Re: Fitting a K04 intake to a K03 Engine
« Reply #1 on: August 06, 2012, 10:41:27 pm »
You will just need to get a bung to block the dv port on the intake. Apart from that it will fit just fine.
Offline Dan.b
« Reply #2 on: August 06, 2012, 10:44:32 pm »
Thanks for your reply. Any ideas what size bung and best place to get it?
Offline 56OctyVRS
  • -Receive: 72
« Reply #3 on: August 07, 2012, 09:30:14 am »
A company like forge or some one similar sell alloy bungs and silicone hose. It all depends on how wide the dv port is. If it is a bsh intake then someone like Dubtek would sell the bhs port bung.
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #4 on: August 08, 2012, 10:46:24 pm »
if it's a BSH intake sell it on and buy something else. they're utter tat (speaking from experience)
PLANS: Stage 2+
Offline Dan.b
« Reply #5 on: August 09, 2012, 08:17:59 pm »
Yes it is. Il wait until its fitted before I comment. I've read that all the intakes are sh*te from different people so thought I'd start with cheapest 1st! Lol
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #6 on: August 09, 2012, 09:34:05 pm »
not referring to the power gains. they don't fit properly, look untidy in the engine bay because of the way the tubing sits and they move about under load and the pipe rubs against the housing causing it to cut a hole in the pipe. i've had to pay another £200 odd to get vRSAlex to totally redesign mine so it works and fits properly
PLANS: Stage 2+
Offline Dan.b
« Reply #7 on: August 09, 2012, 10:26:41 pm »
My one hasn't got the filter tray as its running a larger cone filter so shouldn't have that problem.
Obviously movement might be an issue but nothing I can't sort.
