Author Topic: Hurdy's Golf .:R.  (Read 903713 times)
Re: Hurdy's 500+bhp Golf .:R
« Reply #2490 on: May 05, 2014, 09:48:15 pm »
Great visual explanation on the balance shaft delete Jake.  :happy2:
Thank you, you are aware of the increased oil pressure right John?
Yes, looking at an extra Mocal oil cooler to help share it out a little.  :smiley:
« Reply #2491 on: May 05, 2014, 09:52:57 pm »
Yes I saw the white RS going up.  :smiley:
&feature=youtu.be...
Ignore the three dots either side.  :happy2:
Offline mk_boy85
« Reply #2492 on: May 05, 2014, 10:35:38 pm »
That's impressive. Well done and great time.
Offline GTI-Ross
  • Learning All The Time :)
« Reply #2493 on: May 05, 2014, 10:54:44 pm »
Great job man,  :happy2: :happy2: :happy2:
Offline vRSAlex
  • -Receive: 253
« Reply #2494 on: May 06, 2014, 04:08:38 pm »
Yeah it's way too high.  Just remove the balance shafts from the TFSi setup.  Then you don't have to remove the crank to swap over the gears.
Follow AKS tuning on Facebook
Offline goosie
« Reply #2495 on: May 07, 2014, 05:53:41 pm »
Wow Hurdy, this build is insane! I think I'm in love lol
Offline Pikey Motorsports
« Reply #2496 on: May 08, 2014, 02:37:56 pm »
Woukd the rs4 injectors alone not be enough for the 71r  capabilty do you not think john? Or you planning going bigger turbo again?
TSR PERFORMANCE GTX30 520BHP
LITCHFIELD R35 GT-R 660BHP
MSL E63 AMG 720BHP
HCP BM3 M5 800BHP
« Reply #2497 on: May 09, 2014, 12:00:46 am »
At my level of tune the RS4 injectors are ok. Whether or not they will be good enough to run the HTA3071 to its maximum remains to be seen. There are a lot of rumours, myths, urban legends etc about what different types of injectors will flow on the TFSI and the only real way is to try a set and see how they perform.  :happy2:
« Reply #2498 on: May 09, 2014, 12:03:34 am »
A quick pic of the Nortech kit against the K04. What a difference in build and quality.  :drool:
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=maetubd746bo99ic1bik1vh8p7&/topic,19740.0.html
« Reply #2499 on: May 09, 2014, 12:06:37 am »
Well... one is custom fab and the other mass produced so thats expected.
the kit look mega in that photo.  :love:
« Reply #2500 on: May 13, 2014, 09:03:04 pm »
Update....
Did a few logs in the last few days and found out the MAF maximum reading is 364.08g/s. The GIAC map I run is scaled based on a larger MAF diameter which I am also running. The cross-sectional area is 10% larger and so I'm guessing that this scales the MAF reading by 10%, which basically gives 400g/s. Hopefully after this the map adjusts.
Quick shot of the log.
Offline GTI-Ross
« Reply #2501 on: May 13, 2014, 11:37:07 pm »
Wow...cant believe its holds 2700+ Mbars for so long into the rev range, must feel awesome.
2780 - 1000 (Atmospheric Pressure roughly) x 0.0145 = 25.81 PSI  :laugh: :laugh: :laugh:
« Reply #2502 on: May 14, 2014, 04:22:16 am »
It feels extremely quick Ross. A stage 2 K04 has a boost spike and then drops off, this is like having that boost spike from just after 3.5krpm all the way to the redline and then into the next gear, and the next, and the next!!  :driver:
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #2503 on: May 14, 2014, 07:32:01 am »
Hurdy, I saw your Santa Pod race with the V8 Chevy drag car an it was really impressive.  :notworthy:
I have a very very fast car  :congrats: .
Offline Janner_Sy
  • -Receive: 113
« Reply #2504 on: May 14, 2014, 06:26:23 pm »
Update....
I thought yo would have been running the rail pressure at a higher value tbh.  The APR Stage 3 setup uses around 150bar iirc
