Poll
Which are the best value
Weitec Hicon GT
5 (20.8%)
Koni Coilovers
1 (4.2%)
FK Konigsport
1 (4.2%)
FK Konigsport Silverline X
3 (12.5%)
KW Variant 1
12 (50%)
Eibach Pro Street S
2 (8.3%)
Total Members Voted: 24
Author Topic: Coilovers poll  (Read 10418 times)
Offline scarpicus
Offline TomB
Re: Coilovers poll
« Reply #1 on: June 08, 2009, 01:35:43 am »
There are lots of different budget coilovers there! What would you prefer to spend and how many miles do you plan on doing on them?
I've had KW V1's and FK Silverlines on previous cars and they're both very good kits, the FK's are softer and go lower than the KWs, but the quality isn't as good as the KW's.
The Weitec stuff is made by KW, but I haven't seen it so I can't say anything about the quality.
Tom
05 GTI - 18" Merc wheels, coilovers, colour coded Votex kit, all waiting to go on.
Offline WhiteGTI
  • F-A-S-T
Re: Coilovers poll
« Reply #2 on: June 08, 2009, 09:51:23 am »
You should also consider Bilstein.
It also depends what sort of driving you are doing. If you're going to track it then maybe adjustable coilovers would be worth it (if you know what you are doing). If you are just using them for fast road, then you would be fine with non-adjustable damping. I've heard that its easy to get the adjustments wrong if you don't know what you're doing, and you are not likely to better the set-up on a fixed coilover anyway.
Just my two-pence worth lol!
2006 E46 BMW M3 - 343hp
Offline joesgti
  • Eat my sick, Eat my sick.
Re: Coilovers poll
« Reply #3 on: June 08, 2009, 09:55:31 am »
I have weiteck coilovers, they are the same as KW V1 but run different springs. the ride is a little harsh but i run them very low so its bound to bem i think they were about 450.  :smiley:
Offline tony_danza
  • -Receive: 112
Re: Coilovers poll
« Reply #4 on: June 08, 2009, 10:00:38 am »
Eibachs are also basically a KW v1 with their own spring, this is a touch soft for the track in all honesty, but gives a nice plush ride on the road.
Sideways yo!
Re: Coilovers poll
« Reply #5 on: June 08, 2009, 10:28:26 am »
I guess that VWR-KW-V3's are beyond your current budget :sad:
Professionally set up they are awesome imo.
Offline scarpicus
Re: Coilovers poll
« Reply #6 on: June 08, 2009, 11:43:14 am »
I mainly drive in inner london which has a lot of potholes and humps
I dont plan to track car and i don't do anywhere near the miles im sure some of you do
I probably only drive the car about 10000 miles a year probaly less as its mostly short trips and the occasional motorway trip...
Thanks for that advice as i though it would be simple adjusting damping to suit driving style i am also suprised that the Standard KW varient 1 are ahead of the 2 FK Konigsport coilovers can anyone expand on why KW varient 1 are better.... :happy2:
Really appreciate opinions and advice so far...... :happy2: :happy2: :happy2:
Offline WhiteGTI
  • F-A-S-T
Re: Coilovers poll
« Reply #7 on: June 08, 2009, 11:47:15 am »
^^ As you say earlier, its very simple to actually adjust the damping - most just use a screw adjuster on the top or bottom of the damper - however I was told by suspension experts that its not as simple as just turning the dampers to a softer setting if you're after a softer ride - apparently there are other variables that need to be taken into consideration. But then again I am a complete novice at it, and never really looked into it properly. I guess with a bit of research you could make some good judgements about how to adjust the damping.  :smiley:
Offline scarpicus
Re: Coilovers poll
« Reply #8 on: June 08, 2009, 12:03:48 pm »
So out of the KW and FK which one gave you the better ride also when you say the quality isn't as good can you expand on that...did u have problems with FK
I Didn't consider Bilsteins because ever thing i have read about them people always say that the ride is very harsh.
Offline WhiteGTI
  • F-A-S-T
Re: Coilovers poll
« Reply #9 on: June 08, 2009, 12:18:17 pm »
The ride's not tooo bad, but yeah maybe on the harsh side of things.
My tuner who used to have KW-V3's fitted to his GTI said that they were harsher than the Bilsteins. That probably doesn't help you because I know you're looking at the KW-V1's, but it would be interesting to hear from someone who knows how the V1's differ in ride quality from the V3's, and maybe that could give you a reference point  :smiley:
Offline TomB
Re: Coilovers poll
« Reply #10 on: June 08, 2009, 01:15:26 pm »
The V3's have adjustable damping and rebound, so the ride quality is going to be varied, the V1's are just height ajustable, and they're hard.
Personally for slow driving and potholed roads, I wouldn't go with V1s unless you have a granite spine.  If you're only driving in a congested place, I'd look at something with ride adjustment so you can find some some form of comfort setting.
As far as I was aware, the Weitec and KW kits weren't the same.  The KW's are stainless while the Weitecs are galvanised.  Is that it?
Tom
Re: Coilovers poll
« Reply #11 on: June 08, 2009, 01:46:10 pm »
....Having ridden in Chris' Bilstein GTI on Saturday on the same bit of road as mine with VWR-KW-V3's, I can report very definitely that neither are what I call harsh.
Harder but not harsher.
Much will depend on how expertly the suspension is set up.
Offline scarpicus
Re: Coilovers poll
« Reply #12 on: June 08, 2009, 03:08:09 pm »
So would you recommend FK Konigsport or FK Konigsport Silverline x which i believe are stainless and have damping adjustment
« Last Edit: June 08, 2009, 04:46:28 pm by scarpicus »
Offline true-blue
Re: Coilovers poll
« Reply #13 on: June 08, 2009, 03:22:42 pm »
Hi, Sorry for the OT, but do your FSD's & Eibach's lower the ED30? if so by how much ??
Cheers.
Octavia Vrs MKII - KO4, forge twintercooler, S3 Injectors, APR HPFP, RS4 FP Valve, Pipeworx 3'' DP and Sports cat, Piper non res exhuast, ITG Maxogen, Quaife Dif, sachs clutch kit, NQSBBBK with RS4-2 pads, H&R SS Coilovers with adjustable koni inserts.
Good for 328 BHP on JKM's rollers !!
Offline scarpicus
Re: Coilovers poll
« Reply #14 on: June 08, 2009, 03:38:39 pm »
Replied in For Sale section.. :happy2:
